code 20
Old Aug 22, 2008 | 04:22 PM
tubed-ef's Avatar
Default code 20
dealt with other codes never came across this, searched the forum, came up with nothing, any help?
Old Aug 22, 2008 | 04:56 PM
Maxcapacity's Avatar
Default Re: code 20 (tubed-ef)
Electronic Load detector, I heard it could be caused by a failing alternator..
Old Aug 22, 2008 | 08:30 PM
tubed-ef's Avatar
alright i'm gonna run a test on it tommorow, lucky me i have an extra one sitting around incase it is the problem.
Old Aug 22, 2008 | 09:11 PM
Mr.Death's Avatar
Default Re: (tubed-ef)
ELD is built into the fuse box under your hood. Swap your underhood fusebox for a new one. Problem will go away.
Old Oct 11, 2008 | 05:18 PM
davesrex's Avatar
Default Re: (Mr.Death)
I have this same problem and i have swithched out both the ECU and the fuse box underhood. Still have the code. Could it be alternator? All the tests for the eld are great, everything seems ok but still have code.
Old Oct 14, 2008 | 10:47 AM
redboy183's Avatar
Default Re: (davesrex)
i got the same code problem..so far i have replaced two diff fuse boxes under the hood for good measure, replaced ecus, and put in a brand new altenator in and the code still flashes but car runs fine...weird
Old Oct 18, 2008 | 07:07 AM
Mr.Death's Avatar
Default Re: (redboy183)
Bump for more info.
Old Oct 18, 2008 | 08:12 AM
dacrxguy's Avatar
ill be glad to help if anyone tells me how to copy a page from a pdf(acrobat reader) working on it nao
Old Oct 18, 2008 | 08:22 AM
dacrxguy's Avatar
usdm_ED7
Aug 30, 2011 09:30 AM
mhewitt
Sep 16, 2010 10:03 AM
0ne-Cam
14
Aug 20, 2009 06:58 PM
Gennady
Jan 28, 2002 11:32 AM
