b16 starter issues
Old Aug 22, 2008 | 03:21 PM
SlammedEG6's Avatar
Default b16 starter issues
ok so i just bought a crx..it has a b16a1 swap in it..there is something up with the starter and im not sure what it is..sometimes it starts sometimes it doesnt.. the guy told me if i doesnt start do this
put the car in gear.
have the clutch out.
rock the car to turn the crankshaft and reset the sensor.
then it should start
..which works sometimes but not always.
i dont no what sensor is he talking bout..im new to hondas..kinda..
he said the starter is grounded to the engine.
i really need to figure this out becuase my luck i will get stranded somewhere
id really appreciate it the help..thank u
Old Aug 22, 2008 | 03:23 PM
MyHotsh's Avatar
Default Re: b16 starter issues (SlammedEG6)
Why dont you just get a new starter...
Old Aug 22, 2008 | 03:30 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: b16 starter issues (MyHotsh)
Starter is most likely bad...
Old Aug 22, 2008 | 03:38 PM
SlammedEG6's Avatar
Default Re: b16 starter issues (Dc4iNtEgRa)
ok
Old Aug 25, 2008 | 05:10 PM
wesleywhite989's Avatar
When i ran into this i just bought a starter solenoid kit to replace the contacts on the starter it was like a 20 min job and cost me about $20 instead of the 150 or so a new starter would run me might wanna check it out..
Old Aug 25, 2008 | 06:55 PM
crx_si-r's Avatar
Default Re: b16 starter issues (wesleywhite989)
i have the same issue, i thought it was the starter so i took it off and tested it at my job and it tested fine as did my battery. so i have narrowed it down to possibly being the ignition wire i will be fixing it tomorrow. if it solves my problem ill let the OP know.
Old Aug 27, 2008 | 08:02 AM
crx_si-r's Avatar
Default Re: b16 starter issues (crx_si-r)
ok good news, i just made a new 10g starter wire that goes from my starter solenoid to the main harness plug just under the under hood fuse box, after 1 key turn i have ignition. so to the OP if your still having your srtarting problems try checking that wire. lmk if you need help.
Old Aug 28, 2008 | 04:25 PM
got any pics?
big.turbo.daddy
Jun 23, 2015 06:34 PM
ek4__
Oct 2, 2006 03:06 PM
TiffanyJJ08
Oct 3, 2005 12:35 PM
WTB AUTO EK
May 12, 2005 06:46 AM
Sukebei Oni
Mar 16, 2003 01:21 AM
