need help! need resistance and voltage specs!
i need voltage specs and resistance specs for a 97 integras ignition system...need to check for either cps or a bad icm...not shooting a code but misfires and sputters at 3000rpms or less under load. any help would be greatly appreciated
check out the Factory repair manual you can find it online. its like 1200+ pages and it should tell you how to properly diagnose the situation and have all the specs. I used it to find out that my TPS wires in my harness were all freaked up on my EG. Damn ricers using electrical tape instead of connectors or solder
tuesday night bumppp...anyone have any input on what might cause this or resistance specs for ignition
