tranny problem?
i got a 94 accord...when itake off i hear a grindin noise...sounds like a busted cv boot but all the boots are uncut...when i brake hard i hear clicking...the other day i took my tires off and turned the rotor...i hear a clickin noise comin from inside the tranny where the axles go into...does anyone kno wats wrong with my car? thanks
that clicking is normal when you turn the wheels on a auto tranny. my car does that as I turn the wheel when i was checking for caliper drag. if you have both wheels off of the ground, the one you turn forward and the other one will turn backwards.
Check your brake rotors and calipers, check your VC joints
dude I had a similar clicking sounds - although it was more like a nail rolling aorund in a dryer - which is very similar to what it actually was - the clutch retention bolt had come loose and was rolling around in the trans. Is it a rythmic cosistent clicking?
B16b-EJ8
May 8, 2006 11:23 AM
