B20 Vtec Fuel Pressure reg
hey I got a stock B20B with a B16 head and I just installed a B&M fuel pressure regulator and was wondering whats a good psi to run it at I believe it is set at about 42psi right now is that too high?.
You need an air fuel sensor and gauge. Don't mess with the stock setting until you get that or you risk damaging your motor. Anyone can recommend a psi that works for them but without knowing your set up that's dangerous.
i had a b18c5 now i have b20 vtec.. fuel pressure was around 55 psi at idle for the itr. i didnt change the fuel pressure now i have B20 vtec. is 55 psi too high? what's good fuel pressure for b20vtec at idle?? thanks alot
slowazzhatch
29
Sep 18, 2003 03:57 PM
MyIntegra2Fast
Apr 14, 2003 07:12 PM
