Suspension & Brakes Theory, alignment, spring rates....
Dumb slammed question
Old Aug 21, 2008 | 10:10 PM
alexm's Avatar
Default Dumb slammed question
Right now I'm on Koni sports with GC coil sleeves and GC extended top hats on all 4 corners. I'm pretty slammed but still want to go lower if possible, in the front at least. The bottom of the threaded coil ring is flush with the bottom of the threaded coil sleeve. Can I go a bit lower and hold on by about 3-4 threads instead of 5-6 threads? Don't know, it sounds iffy wondering if anyone has done this before
Old Aug 21, 2008 | 11:34 PM
ejprimo's Avatar
Default Re: Dumb slammed question (alexm)
there is a circlip around the body of the shock that you can remove and place on a lower portion of the shock.
Old Aug 22, 2008 | 07:27 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Dumb slammed question (ejprimo)
which will let the spring go another inch lower on the shock, which will be another 1.5" lower at the tire.
But I'm sure your upper control arms will be smacking the shock towers before then, if they aren't already.
Why in the HELL do you want to get it that low anyway? Maybe for a show or photo shoot where you're not driving, but that's pretty dumb to ride around on the street that low.
Old Aug 23, 2008 | 07:56 AM
johnlear's Avatar
Banned
Default Re: Dumb slammed question (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Why in the HELL do you want to get it that low anyway? </TD></TR></TABLE>
Yet another victim of fashion I'm afraid, it's a sort of irrational car cult fetish...
ZCHondaCRX91
Nov 1, 2015 12:33 PM
der3k
Suspension & Brakes
Feb 23, 2010 12:31 PM
danvuquoc
Suspension & Brakes
Jul 16, 2006 08:12 AM
cheezit
Suspension & Brakes
Mar 16, 2005 08:58 PM
crxaddikt
12
Jun 29, 2004 09:58 AM
