36mm Axle and 32mm Hub problem?
Old Aug 21, 2008 | 10:04 PM
JulioRX's Avatar
Default 36mm Axle and 32mm Hub problem?
I heard the JDM B18cR's have swap problems because the axles are slightly bigger. Im thinking of purchasing a complete swap from Password with the mounts and axles. I have a 95 coupe by the way. IF this does happen how is it solved or will it happen regaurdless. just some info would be nice. Please dont flame.
Old Aug 21, 2008 | 10:53 PM
Bob Dole!'s Avatar
Default Re: 36mm Axle and 32mm Hub problem? (JulioRX)
Any b-series axles will work!
Old Aug 21, 2008 | 10:58 PM
BlueIntegraBoy's Avatar
If you are getting a USDM ITR or CTR 5-lug, the stock d-series or b-series axles will work.
If you are getting a 98 spec JDM ITR, you will need to swap out the outer joint of the axles with one from a Prelude, Accord, or CRV.
Old Aug 22, 2008 | 04:40 PM
JDM_EK_JOE's Avatar
Default Re: 36mm Axle and 32mm Hub problem? (BlueIntegraBoy)
my swap is a 97 swap..the b series axles should work with the jdm trannie?
Old Aug 22, 2008 | 04:43 PM
JDM_EK_JOE's Avatar
Default Re: 36mm Axle and 32mm Hub problem? (JDM_EK_JOE)
the 98+ jdm itr trannie is the 36 spline one only?
Old Aug 22, 2008 | 10:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_JOE &raquo;</TD></TR><TR><TD CLASS="quote">my swap is a 97 swap..the b series axles should work with the jdm trannie?</TD></TR></TABLE>
Yes, the splines going into the tranny and halfshaft are the same as any b-series.
Old Aug 22, 2008 | 11:41 PM
BrakeExpert's Avatar
you know when people do K swaps, they put the B series 32mm ends on the K series (36mm) axles. I'm willing to bet if you get the 32mm axle end and put it on, it'll work.
Old Aug 22, 2008 | 11:55 PM
JulioRX's Avatar
Default Re: 36mm Axle and 32mm Hub problem? (BrakeExpert)
so if I get the 96 jspec it will have the 32mm hubs? Only the 98+ have the 36mm? I don't know if I'm willing to sacrifice the 4.7 final drive. Or does it really make a difference from the 4.4 or 4.7. Of course I want the 4.7 but I'm going on easy swap. What kind of work would need to be done to make the 98+ jspec work?
Old Aug 24, 2008 | 10:27 AM
JDM_EK_JOE's Avatar
only the 98+ jdm trannies have 4.7? when i drove the car the final gear revved much lower than the usdm trannie does...
Old Aug 24, 2008 | 10:44 PM
JulioRX's Avatar
Almost postive on the 98+ have the 4.7 final drive. The USDM ones and the 96+ have the 4.4 i believe.... Im probally wrong... I wish someone would answer that last question because im just about to go k-swap
lsd96teg
Oct 18, 2010 08:26 PM
NA425DragSter
Northwest (Sales)
Jul 30, 2007 03:51 PM
EGB18
Jul 12, 2004 07:49 AM
jdmjohn02
Jan 10, 2004 06:36 PM
pennies_hatchie
Dec 19, 2003 02:04 PM
