wat the caused of white smoke when start up
Old Aug 21, 2008 | 08:54 PM
PRIMITIVEALLMOTOR's Avatar
Default wat the caused of white smoke when start up
does anyone know the cause of white smoke when starting up. what i think is burning cooling or what???? can anyone tell me the problem
Old Aug 22, 2008 | 08:22 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: wat the caused of white smoke when start up (PRIMITIVEALLMOTOR)
way too much fuel might give you that.. otherwise, it may be coolant. what does it smell like? gas? or does it smell sweet?
you should take off your oil cap, and if it looks like a milkshake exploded, then your headgasket is bad.
Old Aug 22, 2008 | 11:07 PM
Default Re: wat the caused of white smoke when start up (sanimalp)
i'm thinking that it is the head gasket too. when i open my vaule cover it has white thing like milk. At first i thougth that it was the throttle that i put in. it was a str 68mm that was used and didn't came with a gasket. but know it coming out a lot of white smoke. and i found out that when i took off my spark plug it has oil on it also. cuz everything is fine but the white smoke is their.
Old Aug 23, 2008 | 12:42 PM
98vtec's Avatar
moderator emeritus
condensation also can be white at startup. If its milky on the inside, that tells me water is in the system.
Old Aug 23, 2008 | 01:44 PM
Default Re: wat the caused of white smoke when start up (98vtec)
i let it run for a good 10 min but it is still wat it is. i'm thinking of of using of spoon head gasket on it first to see wat going to happend from them on. n i get but to ya asap
civ97
Mar 31, 2009 07:56 PM
project ak
Jul 28, 2006 03:00 AM
Civic Hx-T
13
Apr 14, 2005 05:15 PM
BoOsTiN Dc2
Jul 3, 2004 08:19 AM
plastik462003
May 24, 2003 10:47 AM
