Compression check out at 175 across the board?????
Old Aug 21, 2008 | 05:21 PM
mn_babyboy's Avatar
Default Compression check out at 175 across the board?????
What can be the problem? rings, head gasket, valves. Anything else???
Old Aug 21, 2008 | 06:37 PM
ITR.#1446's Avatar
Default Re: Compression check out at 175 across the board????? (mn_babyboy)
if they were the same i would be happy could just be your guage thats why its a low reading, try someone else's i know my reads in the middle compared to my friends his one reads low like your and my other friends guage reads high. If you had numbers that were like 175 140 120 160 then i would be worried.
Old Aug 21, 2008 | 07:58 PM
mn_babyboy's Avatar
That was my first thought. Thanks.
Old Aug 21, 2008 | 08:04 PM
mn_babyboy's Avatar
Also car does not smoke at all. But it is running very lean. I check the plugs, or it can be very old.
oranginal
Apr 27, 2006 12:52 PM
mugenwannabe
May 11, 2005 08:14 AM
Pandahatch
Aug 31, 2004 11:59 PM
Ahab
Sep 4, 2002 12:16 PM
GSR44
Jan 11, 2002 09:58 AM
