Old Mar 25, 2015, 12:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
Removal and replacement of front bumper cover on 96 Accord
Old Aug 21, 2008 | 01:48 PM
koosmar's Avatar
Default Removal and replacement of front bumper cover on 96 Accord
I have a bumper cover to replace my damaged front cover on my 96 Accord LX. My Hanes manual tells me I need to remove the front headlight assembly to remove the cover, which is true in that there are these plastic inserts and plastic screws all along the top of the cover that hold it in place and two of them are under the head light assembly and a third under each of the turn signal light assemblies. My Hanes manual said to go to a different chapter for removal of the head light assembly and there it said I needed to remove the bumper cover first. Visually looking at where the various retention screws/bolts holding the front headlamp assembly in place are located, gives me the same impression, I have to remove the bumper cover first, but I can't do that because I can't get the plastic screw/retaining inserts out that are below the headlamp assembly. Technically, I can remove the old bumper, I can rip it out, breaking the holes where those insert/screws are under the headlamps, but the installation afterwards, I can either put in the head lamps and the bumper cover with only the two inserts on the outsides where the signal light assemblies are and the three in the middle where the grill is and forget the two on each side that sit underneath the headlamp assemblies, or forget about putting the headlamp assembly back in. Obviously, not having headlamps is not an option, but I don't want to have the cover not fully secured on the top. Anyone got a way around this conundrum?
Old Aug 21, 2008 | 02:19 PM
TheMuffinMan's Avatar
He knows where you live!
Take off the actual bumper reinforcement it's much easier.
remove grill
remove turn signals (one screw from hole inside lower grill)
2 bolts behind each turn signal
1 phillips behind each corner light in fender well
1 bolt at the bottom with the inner fender lining
Old Aug 27, 2008 | 11:00 PM
Grant8311's Avatar
Thanks. That helped a bunch. much quicker than the method I used on my last accord
deathman68
Apr 2, 2006 02:29 PM
Layziebtnh055
May 14, 2004 04:37 AM
flat-blk-HB
Aug 20, 2002 10:32 AM
Hcivic88
May 25, 2002 11:03 PM
Jonathan_ED3
Mar 12, 2002 02:31 PM
