HI I REALLY NEED HELP FOR MY 2008 CIVIC SI..
MY SISTER WAS DRIVING MY CAR YESTUDAY AND WHEN PUT DESEL ON MY CAR INSTED OF PREMIEM...AND SHE DROVE THE CAR FOR 10 MIN AFTER THAT...ON HER WAY HOME SHE HER A NOISE BUT SHE DOSENT KNOW WHAT IT WAS...WHAT CAN I DO?..SOMEONE PLEASE HELP ME...
Drain the fuel, install the correct fuel, replace your fuel filter, install new spark plugs and pray.
Modified by EL Vap133 at 3:24 PM 8/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">Your spelling sucks.
There's no need to use caps lock.
You're in the wrong forum.
Your sister needs to be laughed at and punished.
Drain the fuel, install the correct fuel, replace your fuel filter, install new spark plugs and pray.</TD></TR></TABLE>
amen
amen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">Drain the fuel, install the correct fuel, replace your fuel filter, install new spark plugs and pray.
Modified by EL Vap133 at 3:24 PM 8/21/2008</TD></TR></TABLE>
x2
x2
Since the fuels system is returnless I would think you could drain the fuel tank completeley fill it up with fuel remove the fuel rail and cycle the ignition without cranking it. The fuel pump primes everytime you turn the key to ACC and this would flush the fuel line without having to replace the filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 »</TD></TR><TR><TD CLASS="quote">why wasnt she in the kitchen? see what happens.....</TD></TR></TABLE>
There's no need for sexist comments.
OP have your car towed to the dealer and just be honest with them because they're gonna find out anyway. Don't drive it anymore until it is fixed.
Quick question though....did she realize she put diesel in it before or AFTER she drove it home??
Keep us updated. Good luck!
Diesel has a much higher flash point than premium fuel, so no worries about detonation.
I saw a TV show, top gear I believe, about mistakenly putting diesel in gas operated vehicle and vice versa and the myths related about the parts having to be replaced. I just can't remember if I was watching it on TV or on YouTube.
Found it
http://www.youtube.com/watch?v...lated
Watch this before spending a dime !!!!!!!!!!!!!!!!!!!
Modified by Kidnkorner at 8:42 PM 8/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidnkorner »</TD></TR><TR><TD CLASS="quote">Found it
Modified by Kidnkorner at 8:42 PM 8/21/2008</TD></TR></TABLE>
lol. "MEN are twice as likely to commit this humiliating error as women!"
So according to that video he can just fill the rest of the tank up with premium and it'll be fine?? Seems a little too..........easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 »</TD></TR><TR><TD CLASS="quote">i freaked out when i mistakenly put mid-grade in instead of premium. </TD></TR></TABLE>
As with any car manufacturer, Honda designed the Civic Si to be able to run on regular unleaded in the absence of premium.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ »</TD></TR><TR><TD CLASS="quote">So according to that video he can just fill the rest of the tank up with premium and it'll be fine?? Seems a little too..........easy.
I would seem to think that it would be a lot less expensive to go that route, drain your fuel tank, fill up with premium and turn it over until it was a go.
Often people skip the most obvious or simplest steps in trouble shooting because they think that it's too simple only to return later slapping their forehead realizing hind sight is 20/20.
Modified by Kidnkorner at 9:36 PM 8/21/2008
</TD></TR></TABLE>I would seem to think that it would be a lot less expensive to go that route, drain your fuel tank, fill up with premium and turn it over until it was a go.
True. But a scenario like this is different. Honestly if I heard sounds coming from my engine as a result of this type of mishap....my mindset would be that the damage has already begun or taken place and that it's time to take it into the dealer....and HOPE that they have enough integrity to inform the customer that simply draining and re-filling the tank with the correct gas will solve the issue instead of attempting to swindle them out of every dollar they're worth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPEED4 »</TD></TR><TR><TD CLASS="quote">MY SISTER WAS DRIVING MY CAR YESTUDAY AND WHEN PUT DESEL ON MY CAR INSTED OF PREMIEM...AND SHE DROVE THE CAR FOR 10 MIN AFTER THAT...ON HER WAY HOME SHE HER A NOISE BUT SHE DOSENT KNOW WHAT IT WAS...WHAT CAN I DO?..SOMEONE PLEASE HELP ME...</TD></TR></TABLE>
you know, you could be a little more descriptive about the noise that was heard.
From: Westminster/Huntington Beach/Seal Beach, CA, United States
Cause they're trying to help someone out. What if it really did happen and we all just flamed him instead of help...
What if you did something stupid and we all just laughed at you or didn't believe you. That would suck for you huh?
Was talking to about this earlier...hes a mastertech..but anyways on to the point he said he had a customer that took a car in because of that and whatever the diesel fuel touch has to be changed out..il find out more info on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd »</TD></TR><TR><TD CLASS="quote">
you know, you could be a little more descriptive about the noise that was heard.</TD></TR></TABLE>
I call
You cant even put the diesel pump into an unleaded fuel car because the nozzle is a different size.
I call
killerpenguin21
Sep 14, 2008 10:14 AM
Frost_1097
Jan 21, 2007 02:12 PM
Seatown
Jan 10, 2007 08:36 PM
