86CRX si i wana go all out turbo what base motor should i go with? allso i am going all out so plas
Old Jul 23, 2002 | 04:49 PM
Turbo-CRX007's Avatar
Default 86CRX si i wana go all out turbo what base motor should i go with? allso i am going all out so plas
86CRX si i wana go all out turbo i have the pg fi i wana stay with it i just need a good strong base motor that will go in there the budjet is pretty high so i know there are plent of diff. ways of going my goal is to have this little crx keep up with the big boys and there big blocks i know it can be done so help me out i need to kick some big motor a$$ alllso whats the best i can do with the pg fi on the new motor
Old Jul 23, 2002 | 05:27 PM
rioninja's Avatar
Default Re: 86CRX si i wana go all out turbo what base motor should i go with? allso i am going all out so
If your going all out, then get a hasport B-series mount kit and drop in a built B20 (or your choice of Bseries). Fitting the turbo would probably be insanely difficult with a b-series, but just imagine the potential in that light *** car. I think custom radiator is gonna be a necesity.
Old Jul 23, 2002 | 06:04 PM
Mugen Dom's Avatar
bseries mounts 650 + custom axles 250 thats 900 just to make it sit right... then u gotta wire for obd0 witch isnt gonna be insanely hard but difficult i thought about it but ima run a 86 d16a1 with a t3 on it suposidly u can run a vw rabbit rad and it will sit far forward
Old Jul 23, 2002 | 08:47 PM
CRX-TurboMan2's Avatar
hey dude i need more help i got 15 k on it right now and will have more. were i get a b20 that will go in there
Old Jul 23, 2002 | 09:50 PM
89 CRX SI's Avatar
b20 is a honda CRV motor you know the SUV's. it is a 2.0L motor.
http://www.hondamotorsonline.com would be your best bet. but a turbo manifold then a turbo and all the accesories.
Old Jul 24, 2002 | 06:15 AM
rioninja's Avatar
the easiest thing to do, would be to just forget about the B20, and just go with a complete 90-91 LS swap. That way, if your going to build the motor you can just get it sleeved and bored out to 2.0l and have basically the same thing as a B20. Plus, the 90-91 B18a are non-obd motors, which will make the swap very easy. If you just get a plain b20, your gonna need an LS trans/axles/intake manifold/ecu/etc. So you might as well just get the LS swap and go from there. The actual blocks are about identicle in size.
aLlm0t0rboY
51
Oct 9, 2010 05:17 PM
afcfx
Jul 3, 2004 01:00 PM
RACERDAN
Jan 19, 2004 11:55 AM
2camsaam
106
Mar 3, 2003 01:26 AM
