D168Y8 problems galore... please help
Old Aug 21, 2008 | 11:27 AM
everlight44's Avatar
Default D168Y8 problems galore... please help
Well, I've been fixing my car for over a month now and it still has problems. Here are the codes it is throwing:
22 - VTEC coil
65 - Secondary o2 sensor (not worried about this)
91 - Fuel tank pressure sensor
Two questions about this:
1. I can replace the VTEC solenoid if needed, but will a z6 solenoid fit? They are much more plentiful
2. Where is the fuel tank pressure sensor?
And the other problem: bad idle.
I have the 3-wire to 2-wire conversion (throttle body IACV to y8 engine harness) and have replaced the IACV, but the car still idles between 1500-2500 rpm. When I replaced the IACV it went down from 2000-3000 to the lower numbers, so I think that the IACV is working (no code 14 being thrown either). However, it still idles poorly, and I don't know why. There are no vacuum leaks at all, the IACV is bolted up correctly.
Could someone suggest some things to look for? I guess I don't know what's wrong so I don't know what I am doing in this case. The only thing that I have thought about doing was replacing the intake manifold with one that has provisions for a IM mounted IACV, which is the one that ideally would be on my motor. But I honestly don't know any more... I'm about to just pull the motor and sell the shell and motor separately so someone else can mess with it.
Thanks,
Sean
Old Aug 21, 2008 | 12:46 PM
andoxviii's Avatar
https://honda-tech.com/zerothread/2127246
This thread contains a few suggestions about your bad idle.
I know you aren't throwing a code 14 but this may help still...
Good luck
Old Aug 21, 2008 | 01:10 PM
superfast666's Avatar
Default Re: (andoxviii)
1. there is no vtec coil yes the z6 solenoid will fit
2. pressure sensor is in the tank
Old Aug 21, 2008 | 02:07 PM
Thanks for the help.
I meant the VTEC pressure valve :-/
I cleaned the IACV and put it back on and now it waivers between 1500-2500rpm much more like it did before. There aren't any massive vacuum leaks that I can tell, but I will test out more stuff tomorrow I guess.
Could it possibly be the MAP sensor?
Old Aug 21, 2008 | 02:17 PM
skateboard_ej8's Avatar
im hench irl
Default Re: (everlight44)
Try bleeding your coolant system. Air bubbles in your coolant system can cause a fluctuating idle. (throwing off the iacv sensor)
Old Aug 21, 2008 | 02:31 PM
Burnt Toast's Avatar
Could be caused by a bad gas cap. If it doesn't hold the pressure and leaks, you will throw a code 91. Swap it out with a known good cap from one of your buudies, clear out the code and see what happens.
Old Aug 21, 2008 | 06:21 PM
Default Re: (esco562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 &raquo;</TD></TR><TR><TD CLASS="quote">Try bleeding your coolant system. Air bubbles in your coolant system can cause a fluctuating idle. (throwing off the iacv sensor) </TD></TR></TABLE>
Interesting... how would you recommend bleeding the coolant system? Running the car for a bit with the radiator cap off so it cycles the coolant and can purge air bubbles into the atmosphere?
I just replaced the coolant, so that could possibly be a (or the) problem.
I will also check the gas cap tomorrow.
Thanks
Old Aug 22, 2008 | 09:33 PM
Default Re: D168Y8 problems galore... please help (everlight44)
Any other ideas of things to look for? And is there a sure-fire way to tell if a TB mounted IACV is working?
Thanks
DanielSLe
21
Jan 16, 2023 10:14 PM
itsnotfast
Jun 17, 2010 03:15 PM
13btJim
Mar 10, 2010 07:06 AM
prelude2005
Oct 30, 2004 08:03 AM
delSolLS
Aug 5, 2004 11:10 AM
