Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
si shifter bushings?
Old Aug 21, 2008 | 06:25 AM
Blackknight103's Avatar
Default si shifter bushings?
Has anyone replaced their shifter bushings on their si? Where can i get some? I recently put in a cold air intake and as i was doing it I noticed the cables and everything is like right there in your face! seems it would be really really easy to do for not that much cash out of your pocket.
Old Aug 21, 2008 | 07:11 AM
IT GUY's Avatar
Default Re: si shifter bushings? (Blackknight103)
http://www.twmperformance.com/
good guys. great customer service.
Old Aug 21, 2008 | 07:36 AM
Zeusone's Avatar
corsportusa.com has them to.
a few people have had issues with the twm bushing. the c clip would hit and make it getting into 2nd a bit hard.
Old Aug 21, 2008 | 07:43 AM
Default Re: (Zeusone)
thanks for the feedback.
I ordered them from corsport so hopefully they will arrive soon. Ill post a review with or after the install.
I went down and checked out the stock bushings -> Theres a clip that is a pain in the *** to get off ontop of them and the bushings are stuck in there pretty good! Any suggestions/tool requests on how to pop them out?
Old Aug 21, 2008 | 08:01 AM
Zeusone's Avatar
you can cut the cotter pin off. there cheap if you need it in the future. then remove the bushing. one thing you dont want to do is pull up on the shift cable to much. just do it enough to get the bushing in or out. you can brake it if not careful.
Old Aug 21, 2008 | 08:35 AM
k thanks for the heads up
The_Honda_Guy
16
Nov 28, 2009 06:09 PM
Diversion
16
Aug 10, 2009 12:57 PM
square_1
Jan 31, 2009 09:26 PM
mmajedi
Oct 27, 2007 02:46 PM
PiYoImuT
Mar 18, 2002 10:09 AM
