Crower 3 for b16?
Old Aug 21, 2008 | 12:17 AM
quicksi69's Avatar
Default Crower 3 for b16?
delete
Old Aug 22, 2008 | 08:06 PM
quicksi69's Avatar
ANYONE?
Old Aug 22, 2008 | 08:40 PM
umair's Avatar
i dont think you will make 170 whp with just the cams. i made 175WHP with ctr pistons, stage 4 cams, cam gears h/i/e, 8lbs flywheel and stage 3 clutch.
you are going to need to get some hi comp pistons and it would be better if you get a gsr block with an all motor setup.
i may be wrong but if you have stage 3 or 4 cams you need a 3 angle valve job, port and polished head for optimum performance gains with those cams.
Old Aug 22, 2008 | 10:34 PM
obuhmyuh's Avatar
Default Re: (quicksi69)
i'm not sure about the b-series camshafts but i know a crower stage 3 cam for my d-series requires some major cylinder head modification and machine work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umair &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you will make 170 whp with just the cams.</TD></TR></TABLE>
OP said he has
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksi69 &raquo;</TD></TR><TR><TD CLASS="quote">
I have a b16 with intake, 4-1 2.5" header, full exhaust, adj.cam gears, blox manifold, aem fuel rail,b&m fpr, 7lbs fidanza flywheel.
and crower claims it will add +22 hp to a built b18c, so that might be where there is some confusion.
Old Aug 22, 2008 | 10:48 PM
quicksi69's Avatar
VvPeachyvV
May 6, 2007 11:32 AM
DShowers
Dec 1, 2006 07:21 PM
jdmjeff
Feb 25, 2006 05:06 PM
hb4u2nv
Jun 17, 2004 10:28 PM
hb4u2nv
Jun 17, 2004 09:48 PM
