EE Wagon Trailing Arm ???
Old Aug 20, 2008 | 08:34 PM
EDwEFprts's Avatar
Default EE Wagon Trailing Arm ???
i just had my rear passenger-side LCA rip down and out of my trailing arm. (i'll post pictures soon)
i also just found out that a trailing arm off of a hatch will not fit.
does anyone know if a trailing arm off of a sedan or crx will fit?
(wagon parts are hard to come by since so many parts differ)
Modified by EDwEFprts at 12:46 AM 8/21/2008
Old Aug 20, 2008 | 08:54 PM
PoWeRBaN_PaNdA's Avatar
Default Re: EE Wagon Trailing Arm ??? (EDwEFprts)
From my understanding the front suspension components are the same but the rear is wagon specific.
Old Aug 20, 2008 | 10:26 PM
guysensei's Avatar
Post pics. I know someone who is parting his wagon out just might have the parts you need.
Old Aug 20, 2008 | 10:46 PM
EDwEFprts's Avatar
Default Re: EE Wagon Trailing Arm ??? (guysensei)
PoWeRBaN_PaNdA: thanks.
i just read in hondacivicwagon.com that the wagon trailing arm is longer than all others.
can anyone else back that up?
guysensei: i'll post pictures soon when i have my ipod.
i'm waiting on see if i can pick up a parts wagon here locally.
i'll let you know soon if i want the trailing arm from the person you know.
Old Aug 22, 2008 | 03:56 PM
EDwEFprts's Avatar
here are the picture if anyone cares:
can anyone else confirm that the wagon trailing arms are diff. than any other civics?
Old Aug 22, 2008 | 04:05 PM
phatrick2332's Avatar
100% wagon RTA's are different from any other 4g.
Old Aug 22, 2008 | 04:14 PM
EDwEFprts's Avatar
Default Re: (phatrick2332)
phatrick2332: thank you!
more pic:
Old Aug 22, 2008 | 05:07 PM
Crx Jimmy's Avatar
Default Re: (EDwEFprts)
Just cut a square 1/4" thick steel plate and drill the proper size bolt hole and weld it back in place. overlap quite a bit and it should be stronger than stock. I would just fix it since it can be welded on the car
Old Aug 22, 2008 | 06:38 PM
EDwEFprts's Avatar
Default Re: (Crx Jimmy)
^ i might try that. but would you put the plate on the outside at the front end? the back half of the bolt broke off too, so getting it out might be a problem (requiring drilling).
Old Aug 22, 2008 | 07:29 PM
guysensei's Avatar
I personally wouldn't weld it but its up to you. I know from experience that you pay more for going cheap so i would just replace the part.
Old Aug 22, 2008 | 08:53 PM
ludesrv's Avatar
Ya it's all wagon specific in the back (learned this the hard way with rear wheel cylinders). That's some bad luck. I've never seen trailing arms fail like that before.
PS: My wagon is a carbon copy other then the rims.
Old Aug 23, 2008 | 07:43 AM
Crx Jimmy's Avatar
Default Re: (ludesrv)
if the nut is welded on the back cut it off and weld plates on both sides then use a longer bolt with a lock nut. I will be much stronger than stock if done properly any good shop should be able to do it if you dont have the facilitiies
Old Aug 23, 2008 | 08:07 AM
~sp33~'s Avatar
EFB055
Default FV-QR
I'd leave it broken, it looks sweet with all that camber.
Old Aug 23, 2008 | 12:55 PM
EE2bitsk's Avatar
just go get another trailing arm at a junk yard.
everything in the rear is wagon specific.
Old Aug 23, 2008 | 10:23 PM
EDwEFprts's Avatar
Default Re: (EE2bitsk)
^ thanks everyone.
i think i'm going to install another arm rather than weld it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">...That's some bad luck....</TD></TR></TABLE>
that was only the start of it. it was in front of a stop sign and i couldn't roll it out of the way. then my scooter died. then my road bike.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">... I've never seen trailing arms fail like that before...</TD></TR></TABLE>
me either. i was totally shocked when i saw it. i thought for sure it was just my LCA that broke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">...PS: My wagon is a carbon copy other then the rims.</TD></TR></TABLE>
post a picture.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">I'd leave it broken, it looks sweet with all that camber.</TD></TR></TABLE>
oh ya! maybe i could just weld it up as is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE2bitsk &raquo;</TD></TR><TR><TD CLASS="quote">just go get another trailing arm at a junk yard.
everything in the rear is wagon specific.</TD></TR></TABLE>
that was part of the problem. no yards had parts. but i just found one, so i'll fix it up monday.
i thought that the LCA and other arms are the same. yes/no?
Old Aug 24, 2008 | 06:27 AM
Natural Aspirations's Avatar
did you try http://www.car-parts.com?
Old Aug 24, 2008 | 12:28 PM
EE2bitsk's Avatar
well ya, the LCA struts, bushings and other EF **** will work on it.
its just the actual arm is wagon specific.
Old Aug 27, 2008 | 08:49 AM
EDwEFprts's Avatar
^ thanks for the help.
i found a parts wagon, so i have a new trailing arm.
we'll end things with a picture:
jhmeg2
Apr 7, 2013 07:17 PM
ITR.#1446
Nov 24, 2006 01:57 PM
Nader_D
Sep 2, 2003 01:14 PM
