eg to da suspension swap
Old Aug 20, 2008 | 06:27 PM
Boostn B20's Avatar
Default eg to da suspension swap
i just got my suspension for my EG bout 4 months ago and some idiot wrecked my car last week. can i use my suspension from my EG on my DA. wat do i need to do if possible, and most importantly...is it worth it. just in case i have function form type II coilovers.
Old Aug 20, 2008 | 06:57 PM
Circusraven's Avatar
Default Re: eg to da suspension swap (Boostn B20)
I believe it's pretty much the same, although the front brakes might be a bit smaller than the DA's.
Old Aug 20, 2008 | 07:35 PM
Boostn B20's Avatar
do i have to change the forks?
Old Aug 20, 2008 | 08:57 PM
NorthWest94Teg's Avatar
Default Re: (Boostn B20)
Im new to the Da, but I read you use the eg forks. There is a big write up on g2ic.com on this and suspension set ups. check it out.
Heres a link http://g2ic.com/forums/showthr...ybrid
Modified by NorthWest94Teg at 10:02 PM 8/20/2008
Old Aug 21, 2008 | 12:23 AM
gtec8285's Avatar
yea it will fit you just have to use the front forks to hold it down cause the d.a forks are smaller and the rear all mostly the same
Old Aug 21, 2008 | 03:58 AM
be18see1's Avatar
Default Re: eg to da suspension swap (gtec8285)
you only need dc/eg forks. read the faq's for 90-93 integra.
Old Aug 21, 2008 | 04:45 AM
Boostn B20's Avatar
good write up. everything in a nut shell. wish the pictures wud have worked. wow. it' s almost like someone thought of this before me. crazy huh? i know.
Ssaacckkeedd
Mar 23, 2007 09:01 PM
AmginE
Oct 23, 2004 10:07 AM
Ekonte
Jul 6, 2003 10:11 PM
