wiring harness???help!!!
It doesnt get any easier than this...
Knock Sensor <FONT COLOR="red">Red</FONT>/<FONT COLOR="blue">Blue</FONT> D3
Secondary Intake Solenoid <FONT COLOR="pink">Pink</FONT>/<FONT COLOR="blue">Blue</FONT> A17
...those are the pin locations for those sensors.
[Modified by Jackson, 4:36 PM 7/23/2002]
so what is the easiest way to hook my setup up, i was also told i can tkae my engine harness off my si and it will work ill just have to add knock sensor and the secondary butterflys,and if so wher do i wire these to. on the motoor
ok so i can use the engine harness off my si to the jdm motor and then hook up the senndary butterflys and get my p28 re chipped so i dont have to hook up the knock sensor and unblock speed governor on jdm ecu,s and then i have to swap the vtec selonoid with a usdm one..is that right??if so i kno where the secondary butterfly hooks up to the ecu but wher does it hook up to motor and wher is the vtec selonoid
dailyekhatch
Jan 5, 2011 11:56 AM
JDMb18c1HATCH
May 14, 2010 05:24 PM
