Calling all H swapped Civic's and Integra's
Old Aug 20, 2008 | 04:01 PM
Lude@Heart's Avatar
Default Calling all H swapped Civic's and Integra's
What is your Axle setup with given Mount it.
I want to get a count of how many people run what axle combination with what kit. To see what works best over time.
I used to run DSS Level 1 axles which use the Prelude Intermediate Shaft. This worked great with HCP mounts. Never had a problem. Axles have since then been replaced. Now im running a Accord Intermediate Shaft and a driverside 91 DA axle. I need to replace the passanger side axle still with a 91 DA axle and see if i can get away with running just the DA Inner joint in the trans. OR just swap the Prelude inner joint onto the DA axle.
The reason for me doing this is because when i accelerate in 1st n 2nd (all the gears i have other than 5th) i get a pretty bad vibration (shutter) which i can feel in the steering wheel. Goes away as soon as i let off the gas.
2sLoJR
Mar 20, 2014 10:39 AM
traxxasx
Oct 3, 2008 07:59 PM
tenguin
Oct 10, 2004 03:04 PM
g2lsv
Oct 1, 2004 08:24 AM
philipkrotch
Jan 22, 2003 10:46 AM
