HELP!!! its a 94 hatch
Old Aug 20, 2008 | 03:48 PM
afterdark's Avatar
Default HELP!!! its a 94 hatch
well my bro bought a 94 hatch n the car idles high,reverse lights don't turn on when on reverse, and when pressing brakes cruise control turns on. Anyone know wat can i do to fix any of these problems??
Old Aug 20, 2008 | 03:50 PM
Pothole987's Avatar
Default Re: HELP!!! its a 94 hatch (afterdark)
how high does it idle? reverse lights... check the fuse and cruise, sounds like a malfunction in the brake switch
Old Aug 20, 2008 | 03:57 PM
afterdark's Avatar
it idles on 2-3 on the rpm band....as for reverse lights it aint the fuses...n i mean u press the break pedal n cruise control turns on..
Old Aug 20, 2008 | 04:07 PM
Lateralus_EG's Avatar
Have u tried checking the reverse light sensor? i forget the right name for it but its underneath the distributer and it goes right into the tranny. just a simple 2 wire thing.
Old Aug 20, 2008 | 04:10 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (Lateralus_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lateralus_EG &raquo;</TD></TR><TR><TD CLASS="quote">Have u tried checking the reverse light sensor? i forget the right name for it but its underneath the distributer and it goes right into the tranny. just a simple 2 wire thing.</TD></TR></TABLE>That's the reverse light switch and they have been known to go bad. OP needs to check for voltage at the reverse lights(if he knows how) No voltage means bad reverse light switch, if there is voltage it would mean there is either a bad ground or two burnt out bulbs.
93b18civic
33
Sep 30, 2009 12:50 PM
AH VTEC
Jun 14, 2008 06:14 PM
guero2craze
Apr 6, 2007 09:07 AM
Steak84SS
Jun 10, 2003 06:24 AM
Timmayeg
Sep 4, 2002 11:18 PM
