1998 Honda Civic, consuming oil?
Ok, I have a bone stock 1998 Honda Civic, automatic. So I go to check the oil today and notice its at half, so i just go and top it off. I pour about 1/5 of a qt in so its topped off and start the car and let it run for a few minutes. I turn off the engine and check again and now its below half (dipstick). So I fill the car up again and top it off and drive it around for about 5 minutes, check the dipstick when I get back, and its at the same level. Is there some type of problem?
bump. I think I found the problem, there is like two little solenoids under the dizzy that are like mounted on top of the tranny. I believe I need a new gasket there. Does anyone know what that part is called? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by invision »</TD></TR><TR><TD CLASS="quote">bump. I think I found the problem, there is like two little solenoids under the dizzy that are like mounted on top of the tranny. I believe I need a new gasket there. Does anyone know what that part is called? Thanks</TD></TR></TABLE>
Those would be the automatic transmission shift solenoids. But you shouldn't have engine oil coming from there. Also when you check your oil you need to at least wait a few minutes before checking the level.
Reaccion
11
Jan 18, 2011 04:07 PM
