H22 cut's out. Please help
Old Aug 20, 2008 | 02:42 PM
anth2k4's Avatar
Default H22 cut's out. Please help
Hey I've got a 96 hatch with an H22, with minor bolt-on's, I recently took off my iac and cleaned it with brake cleaner and changed my plug's. (NGK iridium's) Car ran fine (kept the same idle and ran smoother but then next day I went full throttle and the car cut's out on WOT. It's similiar to hitting redline, but I'm only at 6000 rpm, sometimes it surpasses 6000, but sputters and feel's like it's cutting out. Also I had my FPR set at 50 psi WOT month's before, then I noticed it was at like 55-60 WOT after the "tune-up". I tried turning it down, but it seems the adjusting screw doesn't change the PSI at all anymore. I was tinkering with the fuel filter during the tune-up but didn't end up taking it off at all or changing it. Anyone know what is the cause of the problem? I've got no check engine light what's so ever. Car run's perfectly fine. Only does this on WOT.
Old Aug 22, 2008 | 05:54 AM
anth2k4's Avatar
Default Re: H22 cut's out. Please help (anth2k4)
bump
YANG_JDM
Dec 2, 2010 04:40 AM
XRSLUDE
Aug 17, 2006 03:40 PM
Knightmare69
Apr 20, 2006 08:09 AM
mxer518
May 17, 2005 01:11 PM
