Suspension & Brakes Theory, alignment, spring rates....
Need spring/shock suggestion
Old Aug 20, 2008 | 10:53 AM
ruffrhyder's Avatar
Default Need spring/shock suggestion
I have a 98 GSR, NA, mildly built daily driver. I do however seen some weekend drag use. What would be a better spring/shock upgrade. I was looking at some skunk2 shocks with H&R sportline springs. Or should I go with a stiffer rear spring since the car will see some weekend drag use?
Old Aug 20, 2008 | 11:54 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Need spring/shock suggestion (ruffrhyder)
Depends on how serious you want to be!
A drag specific rear spring is going to be KILLER on the streets...close to 1,000 lbs/in rates. This isnt very safe to drive on either.
An awesome combo is Koni Yellows and Ground Control. You can get a higher sprig rate for the rear, like 500 lbs/in, which will help with launch squat and won't be nasty for street use.
Or you could roll Eibach springs on whatever shock you like, and swap out the rear at the track for your drag coilovers
Old Aug 20, 2008 | 01:41 PM
ruffrhyder's Avatar
Default Re: Need spring/shock suggestion (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">Depends on how serious you want to be!
Or you could roll Eibach springs on whatever shock you like, and swap out the rear at the track for your drag coilovers</TD></TR></TABLE>
I was looking into the GC coilovers with maybe 350F/450R spring rates on the S2 shocks.
Do you happen to know what the Eibach sportline or H&R sportline spring rates are?
I also forgot to mention, I dont want more than 2" drop. 1.5-1.8 would be ideal cause the roads here aren't that great at work.
Old Sep 1, 2008 | 08:51 PM
ALLxMotor DA's Avatar
eibach pro kit springs sits nice 1 inch drop in rear and 1'4 inch drop in the front not too crazy for the road
Metal Head
Suspension & Brakes
Dec 3, 2007 11:57 AM
kornerk12
Aug 24, 2006 03:01 PM
greenmonster
Jul 26, 2004 09:08 PM
UncleBen'sRacing
Jun 27, 2003 08:03 AM
rOby
Oct 3, 2002 12:05 PM
