changing rod bearings .. assembly lube or motor oil?
Old Aug 20, 2008 | 08:31 AM
pjr710's Avatar
Default changing rod bearings .. assembly lube or motor oil?
i'm chaning my rod bearings on my d16y8, i'm going to spray everything off w/ brake clean then use some canned air to dry off the bearings and crankshaft. when i bolt everyhting bakc together should i use some assembly lube .. or will some motor oil do the trick?
Old Aug 20, 2008 | 08:37 AM
si_motor_spt's Avatar
Default Re: changing rod bearings .. assembly lube or motor oil? (pjr710)
STP has a engine additive, its a small blue container, and its super thick, perfect for what you need....
Old Aug 20, 2008 | 09:33 AM
pjr710's Avatar
Default Re: changing rod bearings .. assembly lube or motor oil? (si_motor_spt)
aight i'll check it out .. its just called an engine additive? i'm guessin its like a slicker type or fluid than oil? i should just rub that all over the bearings and crank?
Old Aug 20, 2008 | 12:27 PM
Civic9390's Avatar
use assembly lube... oil will only work with the cam(you're even supposed to use assembly lube with those) But on Rod bearings USE ASSEMBLY LUBE and remember ONLY put the assembly lube on one side of the bearings (The Crank Side). not the girdle side(Memorys from my buddie dallas "Oh well thats why it spun")
Old Aug 20, 2008 | 01:03 PM
pjr710's Avatar
Default Re: (Civic9390)
yea i wanted to double check on that ... so dont put anything at all between the bearing and the rod right?
integra3586
19
Aug 25, 2009 09:31 PM
pkolaboy
Jan 9, 2008 08:50 PM
ulemu
12
Jan 3, 2006 12:37 PM
HotWheelz
Nov 2, 2002 10:01 AM
CardDealer
Oct 18, 2002 05:07 PM
