1991 DA GS with B20 Swap !!!!HELP PLAESE!!!!!!
Old Aug 19, 2008 | 10:09 PM
phelps38's Avatar
Default 1991 DA GS with B20 Swap !!!!HELP PLAESE!!!!!!
So i traded my old car for the DA with a b20 in it.. it was leaking fuel from the fuel pressure regulator so i tighten it and now when i give it full throttle around 4.5 rpms it cuts out hard core.. i replace the spark plugs and it still does it.. also the idle is all messed up it jumps up and down from 1 to 1.5 and sometimes to 2 rpms.. and im curious about where the tromstat pug is at on the wire harness cause i can not find it anywhere.. thanks for all your help in-advance..
Old Aug 20, 2008 | 08:43 AM
dadriver's Avatar
Default Re: 1991 DA GS with B20 Swap !!!!HELP PLAESE!!!!!! (phelps38)
1. do you have a check engine light
2. check the grounds
3. is the wireing harnness hacked or is stock
4. what ecu are you useing
5. is it obd0 or obd1 or obd2 ??????
answer
Old Aug 22, 2008 | 08:26 PM
92da9c5's Avatar
Default Re: 1991 DA GS with B20 Swap !!!!HELP PLAESE!!!!!! (dadriver)
idle air control valve probably messed up. the thermostat issue probably if you cant find plug it aint there.
92DAb20b
Nov 15, 2012 09:54 AM
johnnypants
Aug 10, 2011 09:34 PM
dreadhead89
Dec 7, 2009 06:05 PM
eg2GAMEOVER
Aug 30, 2007 05:43 PM
LimeGreenHatch
Dec 26, 2005 06:47 AM
