need help fixing oa fan switch.
Old Aug 19, 2008 | 09:07 PM
kit50si's Avatar
Default need help fixing oa fan switch.
ok my brother got a 94 ls with a b16 swap all the wiring is messed up and we can't seem to get the fan running . don't know much about this can somebody help. We need to find it and how to test it. if that does not work is there any way to re-wire the fan
Old Aug 19, 2008 | 09:21 PM
IGODWN's Avatar
Default Re: need help fixing oa fan switch. (kit50si)
test the fan by hard wiring it straight to the battery if it doesnt come on then the fan motor is bad if it does come on then its still good and if the fuses are good and the relay is good and the fan switch located in the thermostat housing is good then you can hard wire the fan to a power source (battery) put in a switch or to an ignition source so it will be on all the time when the car is running or if on a switch only when you want it on if you want to
Old Aug 19, 2008 | 11:19 PM
2slowGs-R's Avatar
will, you can locate the fan switch and just use a speaker wire or a paper clip to touch both ends together(looping it to touch one another). By doing that, your fan will be automatically on when the ignition is turned to the on position. So your fan will turn on if the fan is still good or it will be on to cool off your engine. GL.
Old Aug 20, 2008 | 03:35 PM
kit50si's Avatar
Default Re: (2slowGs-R)
the fan is still good just checked it but does anybody have a picture of it cuz ive never really dealt with this problem and some body stole my chilton book so were kindda just doing it in the dark. and we need the proper wiring and installation of other stuff on the b16 cuz there are some plugs that are dangling there and cut up hoses that we dont know where it leads to. it just bogles me how this thing runs but it pulls really good.
Old Aug 20, 2008 | 03:41 PM
steveo135's Avatar
Default Re: (kit50si)
to chilton\haynes
get a helms and all your problems will be a lot easier to deal with
Old Aug 21, 2008 | 06:12 PM
kit50si's Avatar
Old Aug 21, 2008 | 08:16 PM
steveo135's Avatar
google search hondahookup manual and sign up or whatever they have everything you need
maglites94
Mar 10, 2012 07:40 PM
93-eghatch
Apr 28, 2010 01:31 AM
Lloyd Xmas
Apr 14, 2010 09:21 AM
ngoldsmith1@gmail.com
10
Nov 27, 2008 01:04 PM
goldito187
Oct 30, 2003 11:18 AM
