97 prelude sh help!!!!!!!!!!!!!!!!
Old Aug 19, 2008 | 05:50 PM
dirtysquirrelracing's Avatar
Default 97 prelude sh help!!!!!!!!!!!!!!!!
I've got a problem with my prelude. I bought it with a cel light and been trying to fix it. Its throwing two codes that come on after 1 1/2 days of erasing the codes with a obd2 scanner. The codes say system too lean and fuel trim problem. I've tried these things:
-Replaced damaged fuel line
-new fuel filter
-blox fuel pressure regulator
-clean o2 sensor
-clean fuel injectors
I've pulled the pluggs and o2 senor and they both have a white coating on them. The car stumbles and shakes when trying to accelerate between 1500-2000 rpms. I think a weak fuel pump may be the problem but I was wondering if anybody else has had this problem or any suggestions.thanks
Old Aug 19, 2008 | 08:34 PM
dorian7's Avatar
Default Re: 97 prelude sh help!!!!!!!!!!!!!!!! (dirtysquirrelracing)
have you tried the fuel pump yet? It is also possible that it is an O2 sensor that is broken.
Old Aug 20, 2008 | 07:06 AM
Default Re: 97 prelude sh help!!!!!!!!!!!!!!!! (dorian7)
I haven't replaced the pump yet. I'm thinking its next on my list. Tommorow I'm going to see If there is a vaccum leak anywhere.
Old Aug 20, 2008 | 09:58 AM
Rob97'SH's Avatar
also check for vacume leaks. Does the idle seem high? Even though its a map sensor system it might cause the CEL. Also on the top of my head check the EGR this might also cause a lean code but I would expect to see EGR code as well.
Old Aug 20, 2008 | 10:14 AM
gstrudler's Avatar
I know you've tried cleaning the injectors, but you might want to pull them out of the car and test them for proper flow. If I recall, they need 5v to open. Also, you might try a fuel pressure gauge on the fuel rail. This should tell you whether it's the injectors or not, or if it's something further back in the line (like the pump).
91blackEF
Apr 5, 2021 03:23 PM
eskimo10
Jul 21, 2009 07:45 PM
Jeremy01CivicEx
Honda Civic (2001 - 2005)
Feb 4, 2009 04:26 PM
Litoman
Aug 15, 2002 07:53 PM
Frcfedintegra
Apr 25, 2002 05:48 AM
