B18c CRX cranks but will not start
Old Aug 19, 2008 | 05:35 PM
mjfx's Avatar
Default B18c CRX cranks but will not start
Background information:
-Engine just rebuilt with all new OEM parts.
-In order to get the engine to crank i have to put it in gear and rock it back forth and then get in the car and try to start it. It cranks but does not start.
-I have power inside the car.
-New battery
-Main relay is clicking
-Fuel pump engages
-Got spark(maybe a weak spark..)
-I tried push-starting it and it does not work.
-Checked relays by the passenger headlight
-Checked grounds
-Checked fuses
-The clutch switch was a problem but I fixed it. It would not crank before that.
Questions:
-Could it be the starter?
-Could the distributor be 180 degrees off?
-Could it be a bad distributor?
-Could it be the alternator?... I don't think it's this one.
-Anything else?
Old Aug 19, 2008 | 05:44 PM
ekb16's Avatar
fuel,spark and timing
Old Aug 19, 2008 | 06:37 PM
mjfx's Avatar
Default Re: (ekb16)
Did you read what I wrote?
mhax
Oct 6, 2015 06:22 PM
poptik
Nov 25, 2010 07:11 AM
7panget
Nov 15, 2007 01:32 PM
themex77
Feb 16, 2007 08:58 AM
jkeno112
Oct 16, 2005 05:35 PM
