b18b1 head on b20b or b20z block
Old Aug 19, 2008 | 04:01 PM
Steven.'s Avatar
Default b18b1 head on b20b or b20z block
Ok, I'd like to know if my b18b1 head will directly bolt up to the B20b OR b20z.
Ive done a ton of searching here, and thru google.
Im recieving mixed answers.
From what ive read the b18 and b20 head are the same.
So with a b20 block and b18 head, i would probably use the b20 gasket because of 84 mm and not 81 mm, right?
Same oil pump and water pump, and a timing belt, ecu for b20 or b18?
Let me know!
Modified by Steven. at 5:12 PM 8/19/2008
Modified by Steven. at 10:08 PM 8/19/2008
Old Aug 19, 2008 | 04:45 PM
HONDRETTI's Avatar
Default Re: b18b1 head on b20b or b20z block (Steven.)
i'll share some of what i assume i know since no one has answered yet...
your b18b head will bolt up to a b20b, not sure about the z.
use the gasket for the block your using, OEM of course.
you can use the same oil and water pump. if you were going vtec use vtec pumps.
now my ?'s... why not go ls/vtec? why not go b18 bottom? ive heard negative things about cylinder walls in b20s for higher hp ratings.
SIEf89
Dec 31, 2011 03:02 PM
Tong.Y
Engine Management and Tuning
10
Dec 14, 2009 09:16 PM
mrxracing
Jun 6, 2004 08:23 PM
PrOjEcTpImPcIvIc
Nov 12, 2003 12:25 PM
96Integ
Mar 8, 2002 08:09 AM
