rear lower tie bar dosn't fit right...
Old Jul 23, 2002 | 01:26 PM
Zer0DazE's Avatar
Default rear lower tie bar dosn't fit right...
i have a 95 dx hatch and a ST rear anti sway bar. i have to put washers inbetween the frame and the tie bar, and use a longer bolt. the lower bolts where the sway bar mounts are in the way of the tie bar.
has anyone else run into a similar problem, or if you have the same sway bar and your tie bar fits, what tie bar are you using? and after installing a sway bar does the tie really do anything?
thanks
Old Jul 24, 2002 | 10:18 AM
Zer0DazE's Avatar
Default Re: rear lower tie bar dosn't fit right... (Zer0DazE)
ttt
i cant be the only person with this kind of issue. there has to be someone else with a ST sway bar... what tie bar are you using with it.
Old Jul 24, 2002 | 11:14 AM
ZUL8R's Avatar
i got ST bars with a matrix lower tie bar. its a tight fit 98 civic dx
Old Jul 24, 2002 | 11:43 AM
eg6sir-s's Avatar
the st sway bars were not meant to fit with any aftermarket tie bars at all. as a matter of fact if you buy a neuspeed rear lower tie bar the instructions explain that the tie bar will not work with st sway bars...
don't worry we made st sway bars work with neuspeed tie bars with two different cars...not an issue.
to be continued...
Old Jul 24, 2002 | 12:12 PM
brcivic411's Avatar
Default Re: rear lower tie bar dosn't fit right... (eg6si)
to be continued...
did you have to alter the st sway bar brackets?
Old Jul 24, 2002 | 12:20 PM
Zer0DazE's Avatar
Default Re: rear lower tie bar dosn't fit right... (brcivic411)
thats kinda what i did. i took the spacers out of the lower bolts and used them on the tie bar, with 12x100 mm bolts.
Old Jul 24, 2002 | 06:01 PM
civEX's Avatar
My rear sway bar didn't fit right either, it had a 1/4inch gap from the bar and control arms and it hit my exhaust too. (Addco) Finally a longer spacer and bolt was put in, which worked, but now my car creaks on turns.-- .
Old Jul 25, 2002 | 05:04 AM
ZUL8R's Avatar
Default Re: rear lower tie bar dosn't fit right... (civEX)
if it is creaking , lube the bushings. my front was doing the same thing . i didnt lube them enough the first time and they started. bout a week later i did them up and no squeeky anymore. now just the rear creaks alittle
honda_coupe
May 24, 2009 05:04 PM
94b16coupe
Suspension & Brakes
Jan 4, 2008 05:22 AM
revvin9k
Aug 5, 2004 09:14 AM
^Sammy]!.
Feb 7, 2004 08:15 AM
