jdm itr swap into 96 civic cx hatch...
Old Aug 19, 2008 | 02:35 PM
JDM_EK_JOE's Avatar
Default jdm itr swap into 96 civic cx hatch...
hey guys..
i just would like to know whats involved for installing a jdm itr spec motor into a 96 civic hatchback. i will be converting to obd1 using a obd conversion harness and running a P28. I have a stock sohc motor in it right now and i would like to know what type of wiring do i need and if i can use the stock motor/trannie mount from the D-series and the b16a2 rear trannie bracket. also how about the torque mounts? will the itr ones work? and driveshaft because its jdm can i use a b16 outer axle end and does it work with jdm shaft? please if im forgetting anything let me know. knock sensor? what is it and do i need to wire it up?
Old Aug 19, 2008 | 03:29 PM
rarrior23's Avatar
Default Re: jdm itr swap into 96 civic cx hatch... (JDM_EK_JOE)
Check the Engine Swap Info & FAQ thread at the top of the page, you'll find lots of help in there.
megaman_x
Mar 6, 2013 12:09 PM
akteamster
Northeast (Sales)
May 14, 2007 11:23 AM
b18c1_powered_si
Aug 24, 2002 06:00 PM
