Need some pointers. Please.Foglights and Lips.
Old Aug 19, 2008 | 02:25 PM
mortificationrock's Avatar
Default Need some pointers. Please.Foglights and Lips.
Ok as you all know or might not know I own a 97 Ej8 EGP color. I just went ahead and bought some Yellow Depo Foglights and a Type R Lip. Finally.LoL. Does anyone have any DIY or pointers when installing these? Especially the lip cuz it only came with 4 screws? What's the best way to install it?
Old Aug 19, 2008 | 08:10 PM
Default Re: Need some pointers. Please.Foglights and Lips. (mortificationrock)
Old Aug 20, 2008 | 01:04 AM
riceburnerryan's Avatar
search... or go to the FAQ at the top of the forum
Old Aug 20, 2008 | 06:59 AM
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">search... or go to the FAQ at the top of the forum</TD></TR></TABLE>
I did search and there was nothing on installing. I also went to the Faq's and didn't see anything on lip installations. My concern is am I suppose to bolt the middle part of the lip or am I ok just with the side ones? As far as the fogs I can handle my own. I might even do a write up for peeps out there.
Old Aug 20, 2008 | 07:28 AM
sde780's Avatar
I can help with the fogs, don't have a lip on my car so idk about that
Old Aug 20, 2008 | 07:32 AM
OMGWTFBBQ!'s Avatar
You only actually need 2 bolts to hold the lip on. One on each side. You don't need any bolts to hold the middle of the lip.
Old Aug 27, 2008 | 10:14 AM
Default Re: (OMGWTFBBQ!)
Bump
I need some pointers on how to pass the wire from the fogz thru the firewall. There aint any openings I can see. Any help is appreciated. After some one helps me ill try to do a DIY for people with 96-98.
Old Aug 27, 2008 | 10:41 AM
alphalanos's Avatar
I have two screws on each side of my lip inside the wheelwell . Seems to work ok.
As for the foglight wiring. There should be a small plugged hole under the brake master cylinder. If you go inside the car look under the drive side dash and pull the carpet back, You should see a small plug just push it out then look in the engine bay youll see where it is.
Old Aug 27, 2008 | 11:14 AM
Default Re: Need some pointers. Please.Foglights and Lips. (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">I have two screws on each side of my lip inside the wheelwell . Seems to work ok.
As for the foglight wiring. There should be a small plugged hole under the brake master cylinder. If you go inside the car look under the drive side dash and pull the carpet back, You should see a small plug just push it out then look in the engine bay youll see where it is. </TD></TR></TABLE>
Thanx....ill see if I can find that plug
Old Aug 27, 2008 | 11:24 AM
andoxviii's Avatar
You don't need to pass any wires through the firewall. Honda wired it for you already. Look for a small plug tucked away beside your driver-side fender, behind the headlight kind of. Well, atleast that's how my 2000 Civic is...I think the 1997 is like that too...?
EDIT: There should be blue tape around it...that's how you know if its the right one or not.
Old Aug 27, 2008 | 11:31 AM
Default Re: (andoxviii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii &raquo;</TD></TR><TR><TD CLASS="quote">You don't need to pass any wires through the firewall. Honda wired it for you already. Look for a small plug tucked away beside your driver-side fender, behind the headlight kind of. Well, atleast that's how my 2000 Civic is...I think the 1997 is like that too...?
EDIT: There should be blue tape around it...that's how you know if its the right one or not.</TD></TR></TABLE>
Can anyone confirm this?
Old Aug 27, 2008 | 11:42 AM
andoxviii's Avatar
Default Re: (mortificationrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock &raquo;</TD></TR><TR><TD CLASS="quote">
Can anyone confirm this? </TD></TR></TABLE>
You can, by popping your hood. Look on the driver side by the fender. Between the headlight and strut tower.
EDIT: The other end of that wire leads to the back of your fuse box in the driver foot-well. It is also blue-taped.
Old Aug 27, 2008 | 02:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii &raquo;</TD></TR><TR><TD CLASS="quote">You can, by popping your hood. Look on the driver side by the fender. Between the headlight and strut tower.
EDIT: The other end of that wire leads to the back of your fuse box in the driver foot-well. It is also blue-taped.</TD></TR></TABLE>
Well this is all on a 97 Ej8. So I don't know if this applies. Also I bought a Depo kit so will that still work?
Old Aug 27, 2008 | 06:48 PM
DAP97SI's Avatar
Yes, it is pre-wired from factory, there is a brown plug by the windshield washer liquid reservoir, it is taped with a blue tape. I have a 97 DX and it has it the other end is right behind the fuse box, like stated before with a blue tape around it. I have a 97 DX and it has it.
Old Aug 27, 2008 | 08:50 PM
Default Re: (DAP97SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAP97SI &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it is pre-wired from factory, there is a brown plug by the windshield washer liquid reservoir, it is taped with a blue tape. I have a 97 DX and it has it the other end is right behind the fuse box, like stated before with a blue tape around it. I have a 97 DX and it has it.</TD></TR></TABLE>
Ok so far I googled it and it seens you guys are correct. But it seems it was pre-wired for the OEM fogs. Not the Depo ones. Or is it the same ****? Please someone confirm this cuz im gonna remove my bumper and fix my HIDz and install the lip and fogz.
Old Aug 28, 2008 | 08:23 AM
Ok I found the brown plug with a blue wire behind the fuse box so I guess it is pre-wired. Thanx for your help so far. Now I have another Q, how and has anyone used this plug with a Depo kit. How did they manage to wire it up. Cut off the plug or what? I really wouldn't like to mess the harness up but if that's the only way then so be it I guess. But has anyone installed a Depo kit that can give me some pointers. Thanx
Old Aug 28, 2008 | 10:10 AM
nix94delsol's Avatar
Put the 4 screws you got on the sides of the lip, connecting it to the bumper. then on the underside install another 2 screws. you can never be too safe
Old Aug 28, 2008 | 11:49 AM
sde780's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock &raquo;</TD></TR><TR><TD CLASS="quote">Ok I found the brown plug with a blue wire behind the fuse box so I guess it is pre-wired. Thanx for your help so far. Now I have another Q, how and has anyone used this plug with a Depo kit. How did they manage to wire it up. Cut off the plug or what? I really wouldn't like to mess the harness up but if that's the only way then so be it I guess. But has anyone installed a Depo kit that can give me some pointers. Thanx </TD></TR></TABLE>
post a pic of what you got so we can see if it'll work with the stock wiring or not. Mine were Esuse fogs and they were basically plug and play. Attached harness to brown plug behind winshield washer reservoir, attached other harness to the one behind fuse box, mounted relay, found a place to ground it, plugged the other two plugs into the right place on the fuse panel, and mounted the switch. I can talk you through it if you pm me
Old Aug 28, 2008 | 11:57 AM
alphalanos's Avatar
Default Re: Need some pointers. Please.Foglights and Lips. (sde780)
The Depo kit doesnt use the OEM plug behind the washer reservoir. If you want to keep it plug and play that brown plug goes in the fuse panel under the driver dash in #5 spot. Its not hard. Then you just ground it to the existing ground near the hood release bracket.
nemo_4321
10
Sep 30, 2007 06:15 PM
bgtviper
10
May 30, 2007 09:18 AM
qpreludeh22p
Dec 6, 2006 11:09 PM
DumpedDc2x
Nov 10, 2005 06:53 AM
RiceRacist
Oct 17, 2003 04:18 AM
