FS OBD1 Built GSR Swap!!
Price $3000 obo
Motor has maybe 3000 miles on it, doesnt smoke, just replaced the main bearings, rod bearings, thrust washers, resurfaced crank and everything
OBD1 GSR Swap
SRP 11:1 Compression Forged Pistons
Eagle H Beam Rods
Gold Eagle Light Weight Crank
F1 Clutch w/ ACT 8lb Prolite Flywheel / Stock GSR Trans with no problems! FLAWLESS!
AEBS Inake Manifold With ZEX Direct Port Nitrous Kit
68mm Throttle Body
ARP Rod Bolts
DC Sport Header
ACL Main Bearings
ACL Rod Bearings
ACL Thrust Washers
Supertech Dual Reinforce Valve Springs
Supertech Titanuim Retainers
DC Sports Short Throw Shiver
Energy Suspension Shift Bushing
Prothyne Mount Insterts
Wrink Red Type R Valve Cover
Wrinkle Red Fuel Rail
Chipped P28 With Type R Base Map
Im selling the swap for legan issues Im dealing with right now, I will also be selling the EG Shell it was in!
ATTENTION: Motor has never been spread as I have not finished the install for the zex kit yet because Driven burned down I stopped and didn't wanna have the nitrous on the car because it wasn't able to be tuned yet
PICS UP SOON
OBD1 GSR Swap
Eagle H Beam Rods
68mm Throttle Body
ARP Rod Bolts
DC Sport Header
ACL Main Bearings
ACL Rod Bearings
ACL Thrust Washers
PICS UP SOON
kloneoner
Dec 31, 2013 07:43 AM
