P73 ON 99 GSR??? WILL IT WORK?
Old Aug 19, 2008 | 12:53 PM
cavscoutnjtx's Avatar
Default P73 ON 99 GSR??? WILL IT WORK?
I GOT AN AEM V2 CAI, DC 4-1 HEADERS, APEXI WS2 CATBACK AN A SKUNK2 INTAME MANIFOLD... WILL IT WORK? AND IF IT DEOS IT SHOULD BE BETTER BEINGTHAT I GOT THE DIF MANIFOLD (SINGLE RUNNER)
Old Aug 19, 2008 | 01:58 PM
Default Re: P73 ON 99 GSR??? WILL IT WORK? (cavscoutnjtx)
hello ne1?
Old Aug 19, 2008 | 02:42 PM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cavscoutnjtx &raquo;</TD></TR><TR><TD CLASS="quote">I GOT AN AEM V2 CAI, DC 4-1 HEADERS, APEXI WS2 CATBACK AN A SKUNK2 INTAME MANIFOLD... WILL IT WORK? AND IF IT DEOS IT SHOULD BE BETTER BEINGTHAT I GOT THE DIF MANIFOLD (SINGLE RUNNER)
Those pistons will work, it will bump your compression ratio up a bit. Close to a type r depending on what head you use. What cams are you running? Tuning?
Use this
http://www.zealautowerks.com
Old Aug 19, 2008 | 02:58 PM
Horseofcourse's Avatar
I think hes referring to an ECU not pistons.... I would recommend contacting your local Tuning Shop and have them Socket your ECU and tune your vehicle properly
Old Aug 19, 2008 | 03:55 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Horseofcourse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Horseofcourse &raquo;</TD></TR><TR><TD CLASS="quote">I think hes referring to an ECU not pistons.... I would recommend contacting your local Tuning Shop and have them Socket your ECU and tune your vehicle properly</TD></TR></TABLE>
A 99 is OBDIIa. It can't be tuned so easily. OP would have to switch to OBDI for tuning.
Old Aug 19, 2008 | 03:59 PM
letsdrive's Avatar
yes the ecu will work w/ your setup but it wont be perfect.
Old Aug 19, 2008 | 04:23 PM
racebum's Avatar
Default Re: (letsdrive)
37820-p73-a03 is the 98-99 type r ecu. the tune will also be more spot on if you can raise your compression a bit and find a stage-1-ish set of cams
Old Aug 19, 2008 | 06:12 PM
Default Re: (idrivesideways)
i drivesideways wut r u running in ur gsr 2 ge 14.9? i wanna get stage 2 cams but didnt know if i should get a p73 ecu 1st.... so should i get the ob2 to obd1 wire harness? wut else do i need? im not sure
Old Aug 22, 2008 | 08:28 PM
92da9c5's Avatar
Default Re: (cavscoutnjtx)
obdII ya it will work
Old Aug 22, 2008 | 09:29 PM
racebum's Avatar
Default Re: (92da9c5)
i ran a 14.9 with a catback, edelbrock header, k&n filter and a cold night. my new build should do low 14's and still get 30mpg. if you have a 98-99 car you want the ecu i listed above. there are 2 different types of obd2a type r ecu. one has the fuel pressure sensor, the other does not. if you have a 98-99 car you want a03. 96-97 will use a02 with a p73. BTW i have a spare a03 p73 i can't use since i have a 1997.
B18C_EJ8
Apr 7, 2007 04:28 PM
tomlinson619
Jun 26, 2006 08:43 PM
ThatsMyEG
Mar 9, 2005 12:47 PM
bboynekro
Mar 24, 2004 01:09 PM
acuraqc
Jan 24, 2004 06:12 PM
