which Oil Pressure sensor ? .. 2 different designs for the H-series.
The one on the left is off of a 1995 Prelude Si and has 2 nuts up top and the one on the right is off of a 1996 Prelude Si and has an allen-key screw.. Are these OBD specific ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">Compare part numbers.</TD></TR></TABLE>
Do you know which section to look under ?, I can't find it at Majestic's website.
Majestic doesn't list part numbers in their catalog. Even still, I can find the oil pressure switch in majestic catalog nor at slhondaparts.com. Usually, it's listed under the oil-pump section, and it's not listed under cyl block either. Try calling either Majestic or your local dealer.
Found it under engine 'subcord-clamp' - There are two part numbers listed for both 95 and 96.
http://slhondaparts.com/browse...CLAMP
37240-P13-013 SWITCH ASSY., OIL PRESSURE (DENSO) $21.64
37240-P13-014 SWITCH ASSY., OIL PRESSURE (TEC) $22.01
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsjon »</TD></TR><TR><TD CLASS="quote">37240-P13-013
IS THE CORRECT CURRENT NUMBER.</TD></TR></TABLE>
If so, then which one of the two would that be ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 »</TD></TR><TR><TD CLASS="quote">The one on the left is off of a 1995 Prelude Si and has 2 nuts up top and the one on the right is off of a 1996 Prelude Si and has an allen-key screw.. Are these OBD specific ?
The one on the left has been rigged and is not 100% oem. Same with the one on the right.
All H series oil pressure sensors have a tiny 7mm bolt that holds the harness wire in place.
