fuse wont pop on my crx
Old Aug 19, 2008 | 06:01 AM
gabe_si's Avatar
Default fuse wont pop on my crx
Alright well my car has an electrical gremlin...damn bastard is hiding.
Anyways..everything in my car was fine until recently my blinkers,clock,tach, and temp guage dont work along with my reverse lights. The thing is i check the fuse for the clock radio etc and its not popped...But when i take it off and plug it in i see a small spark so i know there a short there... My emergency lights work, my headlights turn on and my instrument cluster and climate control all work and lightup..I went through all the wires other than the clock and i cant find a thing. I have an after market radio and it works.....
Old Aug 19, 2008 | 07:12 AM
beana's Avatar
Default Re: fuse wont pop on my crx (gabe_si)
check the grounds on the engine, i know it sounds funny but do it anyway
Old Aug 19, 2008 | 08:48 AM
crxma22's Avatar
Default Re: fuse wont pop on my crx (beana)
did you try and replace it with a new fuse? just cuz it looks fine doesn't mean it necessarily is good.. i had the same problem.. blinkers, tach, clock.
Old Aug 19, 2008 | 09:28 AM
gabe_si's Avatar
Default Re: fuse wont pop on my crx (crxma22)
yes and it still doesnt work...what grounds should i check and were
Old Aug 19, 2008 | 09:40 AM
crxma22's Avatar
there's a ground under the steering column, connected to a 10mm bolt. maybe you fried that ground wire? (another problem i had in my crx) i ended up just replacing the whole dash harness to save me a headache in the future..
Old Aug 19, 2008 | 09:45 AM
beana's Avatar
check the ground(s) on the valve coverand check the ground on the fuse panel like the other guy said
Old Aug 19, 2008 | 02:50 PM
tnez's Avatar
drink a beer, smoke a blunt, take your interior apart and have fun finding that bastard!... if all else fails that is. gl dude.
lickety_britches
17
May 3, 2009 12:42 AM
185Kaccord97
Nov 12, 2007 01:42 PM
Double_Dk
May 10, 2005 05:03 PM
94BlackEX
Jun 17, 2004 01:31 AM
payneth
10
Apr 15, 2004 03:59 PM
