How many Ingalls front camber kits do I need to achieve up to +/-2 degrees camber?
I ordered one kit (part # 81260) but the alignment tech can only get -1.1 degrees at most by using one bolt on each side. I'm starting to believe that I actually should have ordered 2 kits in order to put two bolts on each side and get up to -2.0 degrees of camber up front. Is that so?
Modified by 405hp at 7:19 AM 8/19/2008
I have the SPC...its able to go up to -1.75
in your case, I would say you will need 2 sets of bolts
