will eg harness plug into the ef cabin?
Old Aug 19, 2008 | 01:38 AM
KHMERXB0I213's Avatar
Default will eg harness plug into the ef cabin?
does anyone know if the obd1 eg interior harness will work on my dpfi ef?....i rather change the whole harness....
Old Aug 19, 2008 | 02:46 AM
goforbroke's Avatar
MEAT PATTY
Default Re: will eg harness plug into the ef cabin? (KHMERXB0I213)
Those harnesses are not even close.
Old Aug 19, 2008 | 05:11 AM
singleslamwonderman's Avatar
Default Re: will eg harness plug into the ef cabin? (goforbroke)
x2. just do the mpfi swap, its not bad. tons of info on here and if you aren't confortable with the wiring contact rywire or check out the wtb section in here. theres a converted harness in there for sale right now.
Old Aug 19, 2008 | 01:47 PM
i was thinking but changin everything....cuz its only 45 bucks...conversion harness are too expensive...i have a d16z6 wit obd1 parts....
Old Aug 19, 2008 | 06:29 PM
goforbroke's Avatar
MEAT PATTY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KHMERXB0I213 &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking but changin everything....cuz its only 45 bucks...conversion harness are too expensive...i have a d16z6 wit obd1 parts....</TD></TR></TABLE>
Your going to spend more money in the long run trying to do like that. Its not even worth the headaches alone. A close friend of mine is going through a similar situation purchased a 93 civic coupe with a gsr and the entire car harness(headlight to tailight) is from a integra, huge PIA
You can't find a cheap ef harness laying around somewhere. People basically give them away. You live in Cali they should be laying around on the street corners.
Old Aug 19, 2008 | 08:57 PM
ok kool..im just gonna leave it dual point for now and wen i have more money ill swap the d16z6 and run it obd1
aolden
Oct 13, 2013 12:40 PM
toolbox21
Apr 30, 2012 01:35 AM
[eg6]
Mar 30, 2011 12:24 PM
accord2civic2prelude
Aug 14, 2009 05:42 AM
Usdmowns
Nov 30, 2007 04:01 PM
