h22 swap wiring/sensors/vacuum hoses
i just picked up a 1994 prelude with a jdm h22 with only 42k on the motor.. but the guy who swapped it has all sorts of crap messed up with the intake/tb.. there seems to be vacuum hoses missing going to the intake and from the head. and there is a sensor on firewall side of the t/b that is missing.. i think its the tps sensor but not sure.. can someone help me out and gimme and idea of what im workin with here and what i should be looking into to get this problem resolved.. thanks
That missing sensor is the TPS.
If it's as bad as you say...you should be getting all sorts of fun CEL codes. Take some clear/detailed pics of the questionable areas in the engine bay and post ALL the CEL codes you're getting so we can offer you better advice.
yea i have to get the cel scanner from autozone tomarrow and i will have all the pic up also.. but i grabbed a t/b that i had from my old teggy gsr and took the tps sensor off and trew it on the t/b.. but i dont have the wiring for the sensor so i have to go pick that up as well. but ill have more posted with pics tomarrow for you do advise.. thanks a lot
dont waste your money on the cel reader just do this and use that money to replace the vac lines and sensors.. some of them arent cheap
http://92lude.com/diagnose_error_codes.htm
im working with
