t/w rust free EF9 built all motor ls vtec
I am looking to trade my all motor EF9 for a ek coupe or EG hatch with b-series swap and clean cars
full wire tuck
battery in trunk
fuse box in glove box
block:
400 miles on motor
ls block std bore
P30 pistons
je pro seal rings
acl bearings
new oem ls water pump
all new oem seals
new oil pan gasket no leaks
cometic ls vtec head gasket
ARP Headstuds
ARP Rodbolts
Golden Eagle Sandwich Plate
Golden Eagle Oil Feed Hose
Golden Eagle VTEC Dowel Pins
1/8" NPT Pipe Plug
Golden Eagle Cylinder Head to AN-6 Fitting
head:
b16 head with slight mill
supertech springs
crower retainers
ITR cams
srp cam seal
aem cam gears
new oem valve seals
all other seals new oem
victor x intake manifold
hondata intake manifold gasket
benen fuel rail
blox FPR
blox fp gauge
450cc injectors
walbro 190 fuel pump
earl fuel filter
power ind. 68mm throttle body
arp extended intake manifold studs
arp extended exhaust manifold studs
tranny JDM b16
act 6 puck clutch
gsr flywheel
full race traction bars
aem intake painted black
jdm ITR header 2.5" collector
greddy mid pipe with magaflow muffler and greddy tip sounds really good
MISHIMOTO full lenght radiator
avid motor mounts
susp.
enki old skool wheels
full omni sports coil over setup
engine mng.
obd1 conv.
p28 on crome
needs a tune
easy 200whp car
exterior
rust free car
has some dings
interior
full black SI interior
si seats
black carpet
alpine deck
Show me what you got
Modified by civic4lif at 8:57 PM 8/18/2008
Modified by civic4lif at 4:35 PM 8/19/2008
Modified by civic4lif at 1:19 PM 8/28/2008
full wire tuck
battery in trunk
block:
400 miles on motor
ls block std bore
P30 pistons
je pro seal rings
acl bearings
all new oem seals
ARP Headstuds
ARP Rodbolts
1/8" NPT Pipe Plug
head:
supertech springs
crower retainers
ITR cams
srp cam seal
aem cam gears
new oem valve seals
benen fuel rail
blox FPR
blox fp gauge
450cc injectors
earl fuel filter
tranny JDM b16
act 6 puck clutch
gsr flywheel
avid motor mounts
susp.
engine mng.
obd1 conv.
p28 on crome
needs a tune
easy 200whp car
exterior
rust free car
has some dings
interior
si seats
black carpet
alpine deck
seriously ppl this thing is ultra clean its originally from texas it has NO RUST the QP's are spotless, underneath its clean. i wish i had something to offer u id trade u back...g/l with ur deal man.
Chris.B.
Mar 5, 2008 09:29 PM
