FS: (EG/DC) AEM intake, 4pt harness, Energy RTA, lightweight flywheel, tower brace, OEM pads, OEM ta
Early model AEM cold air intake- ceramic coated silver, BIG K&N with huge velocity stack inside, clean, 92-95 civics (with B series swaps OK). $75 or best offer.
Koni sport shocks, single adjustable. These are for 88-91 civic/90-93 integra fronts, they can also be used on EG/DC for an approx 1" shortened shock (close to koni race 2812 RACE for EG/DC size) if you use lower forks (included). These are old and used, but not blown, not leaking. Pair of front shocks, forks, brake line bracket, bumpstops, spring perches, circlips, and adjustment ****. $100 or best offer.
Energy suspension urethane rear trailing arm bushings. red. New in box, never opened. 92-95 civic/94-01 integra, maybe other models Part number 16.7106R
Any reasonable offer $20?
Autopower four point racing harness. This is a camlock style racing harness made in JULY 2000 so it is out of date for RACING, but ok for autocross, rallycross, and drifting or just keeping your butt in the seat. Shoulder straps are 3" and for rollbar/harness bar mounting only, lap belts are 2", do not have 5th point crotch strap, black, good condition, kept indoors. $50
B series SOHFAST machined lightened OEM flywheel, 13lbs (stock weight approx 20lbs). I used this for over 2 years with a clutch master stage III, no issues, and when replaced with exedy 9lbs flywheel could barely notice the difference. Surface has some small visible hotspots, best to resurface as with any used flywheel. $50
OEM honda/NISSIN front brake pads. 94-01 integra non R, NEW in box. $30 or best offer. Can get pics if necessary.
AEM short ram intake- Polished, with dryflow filter, clean. 92-95 civics (B series swap ok), and 96-00 civic EX/Si models. New in the box- filter used breifly. $75 or best offer.
Unknown brand rear upper tower brace fits 90-93 integra, 92-95 civic, 94-01 integra.
maybe 88-91 civic, 96-00 civic, but i havent fitted this particular part on these.
Steel powdercoated blue mounts, aluminum adjustable length center. $35 or best offer.
92-95 civic FOUR DOOR OEM tail lights. Used, excellent condition, with hardware.
$30 or best offer.
92-95 civic FOUR DOOR driver's front headlight and corner lens OEM, excellent condition, used. $30 or best offer.
Rather local pickup for these items, will meet buyer in NOVA area.
Thanks for looking, email spilkert@hotmail.com or PM.
$30 or best offer.
