95 H23 balancer shafts. Is it safe to run motor without them?
Does anyone know if its safe to run an H23 motor without the balancer shafts? I put the motor back together after repairing an oil leak, and now I believe I installed the rear balancer shaft gears housing a tooth or two off. I really dont feel like tearing the motor apart again. And a buddy of mine said he took the belt off his H22 and it ran fine. Does anyone else know if its ok? Thanks
Next time you want to make a thread, take some time and use the search button in the upper right and try to find the answer to your question first.
It will be fine to run without them, there are NUMEROUS threads about the subject.
Im sorry about putting a new thread out there. I'm using the computer at work, since I have the car here, and it was faster for me to type a new thread. Sorry about that. Thanks for the info. I think I will be removing the BS belt after all. I believe that my rear BS is off by a tooth or two (I removed the gear housing when I had to repair a groove in my crank where the main crank seal goes. She seeped oil bad. $30 speedy sleeve from SKF solved that problem. But yeah, thanks.
xxredpreludesixx
40
May 17, 2005 07:12 PM
