******* sub install on 1991 civic SI w/ stock deck **********
is it possible to have a sub with a stock 1991 civic si deck. i dont want to change the oem deck, but im thinking about getting a small 8" sub.
thanks for the help
thanks for the help
is a line out converter the same as a high-to-low converter?
ur going to need a high to low converter to get subs with a stock deck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA batmobile »</TD></TR><TR><TD CLASS="quote">is a line out converter the same as a high-to-low converter? </TD></TR></TABLE>
No, I believe you are thinking of a low pass filter. Most amps have these built into them and he probably would not need one.
He needs the line output converter, or an amplifier with one built in.
euromk1s
Audio / Security / Video
May 3, 2008 12:38 PM
mztykal
Feb 11, 2006 10:52 AM
