94 integra LS. Idle revs high to low while stopped.
Old Aug 17, 2008 | 11:11 PM
GREENMOB$TER's Avatar
Default 94 integra LS. Idle revs high to low while stopped.
as the title states, when I'm at idle, stopped at a light or just stopped, the idle goes low to high low to high. puzzles the hell out of me. Is this bad?>
Old Aug 18, 2008 | 12:45 PM
Default Re: 94 integra LS. Idle revs high to low while stopped. (GREENMOB$TER)
bump
Old Aug 18, 2008 | 01:07 PM
EJ6JON's Avatar
seems to me like a clogged up Idle air control valve its on the intake manifold just need to take off clean and put back it gets clogged it has a mesh filter
Old Nov 13, 2008 | 09:06 PM
lsxtreme81's Avatar
i donno but mines doing the same problem but it doesn't go up and down it just stay @ about 1300rpm i've messed around with the idle air valve, i have it where i is all the way down and if any higher i'll gradually raise up higher in rpm so right now it's all the way down and sitting on 1300.. what yal think
Old Nov 13, 2008 | 09:10 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: (lsxtreme81)
ya mines doin it too..im not to worried about it now but it is extremely annoying..
its on the back of the mani between the firewall and manifold right??
Old Nov 14, 2008 | 02:05 PM
mouab18c1's Avatar
Default Re: (stocker2shocker91)
check for vac leaks, bad tb gasket, leaking intake mani gasket........
norcalB18
Dec 7, 2015 10:24 AM
CaliforniaDad
Mar 15, 2012 04:59 PM
gohonda
Jun 23, 2007 01:44 AM
mugen92acintls
Dec 28, 2004 05:38 PM
PSU-TEG
Mar 11, 2003 07:28 AM
