Cant find where the fan wire goes
alright so the fan wire was alredy disconnected for some reason when i got the car so thats why i think i maby be looking in the wrong places
i cant find where to plug in the green connector, I am also assuming that it connects into a realy because how else would it turn on and off.
Help would be greatly apprecaited, my freaking fan is lost
there is suspose to be a female connector that ties in with that wire loom that has green tape on the left of the pic it should be sumwhere around there..it couldnt of walked away too far
thanks allot i did find it where you said, the connector had fallen under the battery bracket and when i tuged the wire before it was not moving. I had thought the wire continued into something else so i stoped pulling on it.
For some reason the connector was cut and then spliced back, since i will drive the car in the winter i will solder and heat shrink the wire to protect it from the elements
FMIDRC Racer
Aug 27, 2005 12:22 PM
Want2race
Jul 13, 2003 11:09 AM
