electrical problem with my s2000 parking lights
i try and search the forum for problems but i couldnt find answer first my s2k's parking light does turn on, my keyless doesnt work i try and take the fuses out and replace a new one, when i replace a new one it keep blowing up, and the other one is when u know when the cluster light get bright when u turn on ur headlight at night, well mine doesnt even get bright anymore ='[
thanks
thanks
nope nothing modification to the electrical in the car and i also found out my backlight doesnt turn on either just got pulled over =[ but lucky the cops let me go
I updated your thread title...
Did you just buy the car or what? So it is 100% stock? Was it before you bought it?
You have a electrical problem in the parking light wiring for sure.
problem solved, i check the fuses so i check every fuses in the car to see if its blown so the "small lights" fuses blow everytime i replace a new one it keep blowing up so i traces down the wires whatever connecting to the parking light , so there was another wire connecting to the sidemarker which makes the sidemarker turns on with the parkign light so i remove the wire and everything works now
thanks for replying but the weird part now is that my car backfire from first gear but i guess thats not a problem =]
2kGSboi
Aug 10, 2001 02:34 PM
