Suspension & Brakes Theory, alignment, spring rates....
spring rate help
Old Aug 17, 2008 | 05:34 PM
josh green's Avatar
Default spring rate help
I am looking to do a suspension overhaul on my 93 hatch and I am needing some advice on spring rates. I will be purchasing koni yellow/ GC combo. I drive my car every day, and the roads here are pretty smooth. I need a spring rate that will be good for mountain runs, occasional track day and every day street driving. I dont want to be beat to death driving it also. I am currently running tokico hp's and eibach springs and the setup seems to be getting tired and bouncy. I will be installing stock LS front and rear sway bars on the car as well as new bushings. Also, I am running a 15/16" wheel setup on the car, I will be running the 16's in the front fyi.
Old Aug 18, 2008 | 11:48 AM
AlphaQup's Avatar
Default Re: spring rate help (josh green)
I'm running GC's 350F/300R and it seems a little too soft for my liking, but then again I have my kid strapped in the back 50% of my driving time. It's definately a good DD setup. I'd say if you have nice flat roads with no potholes to worry about, get 450/400 and call it a day. That's what I'd do if I was to get another set of coils.
Old Aug 18, 2008 | 05:56 PM
josh green's Avatar
Thanks man.
bump, looking for some more input.
Old Aug 19, 2008 | 02:23 PM
ejprimo's Avatar
Default Re: (josh green)
im running 450f/600r ers springs on koni yellows and the ride is rough but its fabulous on the track.
i suggest you 350f/450r to rid the car of some understeer. also a 22mm itr sway bar will help the rear rotate in the turns.
Old Aug 19, 2008 | 04:35 PM
josh green's Avatar
Default Re: (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">im running 450f/600r ers springs on koni yellows and the ride is rough but its fabulous on the track.
i suggest you 350f/450r to rid the car of some understeer. also a 22mm itr sway bar will help the rear rotate in the turns.</TD></TR></TABLE>
What is the likelyhood of getting some unwanted snapping in the rain with those rates? I guess I should just drive slower.
cleen
Suspension & Brakes
17
Apr 25, 2010 04:52 PM
RGoose18
Suspension & Brakes
May 8, 2006 06:13 PM
cubism
Suspension & Brakes
Apr 3, 2006 12:07 PM
Ti Rider
Jan 1, 2006 07:06 AM
RalliartRsX
16
Nov 9, 2005 05:34 AM
