Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
H2 Racer needs help!
Old Aug 17, 2008 | 02:15 PM
ZUL8R's Avatar
Default H2 Racer needs help!
just finished installing the BLOX intake manifold and a used BBK 62mm TB for a B16A2. put on a fuel pressure guage and regulator. I also put in a walbro 255 fuel pump.WHen i start the car it revs up to atleast 6500 rpm and i shut it off.
No fuel leaks...
So i try this ...
I covered the two ports inside the throttle body one at a time to see if that was the problem. nope...
what else can i do???
the fuel pressure guage reads about 34 or so as it revs up, and about 20 when the key is just turned over...
i did a throttlebody bypass ,,,and the intake manifold had an extra cooling nipple under the main cooling hose, i used a T there and looped it...
3 weeks untill i leave far nationals and i still have a Type R cam to install
Help!!!
Old Aug 17, 2008 | 04:28 PM
B16B_coupe's Avatar
HRD PKR
Default Re: H2 Racer needs help! (ZUL8R)
Did you use a new intake mani gasket and throttle body gasket for install?
all vacumm ports plugged on intake?
Sounds to me like you have a massive intake leak. If you plugged the two holes on the throttle body the car should die
Old Aug 17, 2008 | 04:52 PM
ZUL8R's Avatar
Default Re: H2 Racer needs help! (B16B_coupe)
i got a new gasket for the throttle body and for the intake manifold from honda for a 2000 civic Si.
we just went out and plugged the nipple ontop the throttle body and the two ports inside the TB and it still did the same thing...
Damn my neighbors hate me right now
Modified by ZUL8R at 9:03 PM 8/17/2008
Old Aug 17, 2008 | 05:28 PM
B16B_coupe's Avatar
HRD PKR
cover the throttle body with your hand, the car should die.
Old Aug 17, 2008 | 05:31 PM
ZUL8R's Avatar
I will try more tomorrow. id rather not start the car again tonight , its super loud in the garage. Something has to work, i just hate waiting
Old Aug 17, 2008 | 05:40 PM
Lo-Buck EF's Avatar
yea, it definately sounds like a serious IM leak. sounds like u did the coolant bypass correctly (same as mine prittymuch). asside from an obvious stuck butterfly or way cranked up idle screw, i'd double check the few vac lines and make sure nothing underneeth (iac area) is off.
Old Aug 17, 2008 | 05:51 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: H2 Racer needs help! (Lo-Buck EF)
There are two plugs near the TB, one for the IACV, one for something else (been awhile since I messed around back there). They're the same exact type and color of plug, right near each other on the harness, etc, very easy to get them mixed up. Any chance you got them switched? They do weird things when plugged in backwards.
Old Aug 17, 2008 | 06:36 PM
chad's Avatar
Moderator
look.....if the throttle body is closed....and it revs to 6500 plus YOU HAVE A LEAK SOMEWHERE!!!! PERIOD....wires crossed will not make it rev to 6500....THERE HAS TO BE AIR for the engine to run that high....so....that means....intake manifold leak!!!! some where...wether it is between tb and im or im and head there is A LEAK THERE....NOTHING ELSE IT COULD BE!! start it....spray brake cleaner all around im at head an im at tb....if you have an itr tb and got a b16 tb gasket that is your problem there....they are not the same gaskets...
Old Aug 17, 2008 | 06:47 PM
Suspetise...
Default Re: H2 Racer needs help! (chad)
I'm not saying the leak isn't it, but that crossed wire thing did make mine rev up (though admittedly not to 6500).
Old Aug 17, 2008 | 07:10 PM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">look.....if the throttle body is closed....and it revs to 6500 plus YOU HAVE A LEAK SOMEWHERE!!!! PERIOD....wires crossed will not make it rev to 6500....THERE HAS TO BE AIR for the engine to run that high....so....that means....intake manifold leak!!!! some where...wether it is between tb and im or im and head there is A LEAK THERE....NOTHING ELSE IT COULD BE!! start it....spray brake cleaner all around im at head an im at tb....if you have an itr tb and got a b16 tb gasket that is your problem there....they are not the same gaskets...</TD></TR></TABLE>
OP If you do this make sure you have a fire extinguisher or something to put out a fire in case you have a little spilt out fuel!
I bet either you A: have wrong gaskets B: didn't clean all the old gasket off C: the intake is warped
Old Aug 17, 2008 | 07:12 PM
Todd Reid's Avatar
Default Re: H2 Racer needs help! (Stinkycheezmonky)
hi.
i agree with chad, 100%. check carefully and make sure that the main 62mm throttle butterfly is closing all the way when you aren't touching the gas; i saw this exact set of circumstances at last years national races; i was trying to help out a friend, and his car would immediately rev up to 7k+ rpm as soon as he started it.... it turned out that the butterfly shaft somehow got bent a little, and the throttle wouldn't close all the way. we finally figured it out, after removing the throttle body and examining it closely, while hand working the throttle plate opened and closed....
good luck; you'll find the problem soon, and all will be good!
todd
Old Aug 17, 2008 | 11:14 PM
smokin rubber's Avatar
Shane didnt you say you could see light past the blade in the tb, how much?
Old Aug 18, 2008 | 10:06 AM
Egezzy's Avatar
Spongebrad Squarepants
stinky is rite bout the plugs fo the iacv n the purge solenoid valves plug r the same. .but normally when switched it would idle pretty weird.
but since u put the new tb have u calibrated the tps?? my buddy.s car would only rev to 2.5k n then sound like it was bouncin rev limiter befo it was calibrated.
Old Aug 18, 2008 | 02:12 PM
ZUL8R's Avatar
Default Re: H2 Racer needs help! (Egezzy)
heres the problem...
I got these today for the rains.... prolly will never rain ever again at any event i attend
I will be installing the cam this weekend, Dyno tune and corner balance next week and then im off to NAts
Old Aug 18, 2008 | 02:57 PM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">just finished installing the BLOX intake manifold and a used BBK 62mm TB for a B16A2.
...snip...
ZUL8R -
Good to hear that you got it running, I had to chase a few problems around this weekend as well, though I wont be traveling to nationals, this year simply killed the budget.
Slight problem, unless I've read the rules incorrectly, the rules for running in H2 state that the throttle body must be a Honda throttle body, it looks like you're using a BBK throttle body. The specific rule is 10.3.f - "f) Any Honda throttle body may be used providing it utilizes an outlet size of 62mm or less. Over-boring of stock throttle body is permitted."
This was changed in the 2007--&gt;2008 rules, here is how the 2007 rule read: "f) Any throttle body may be used that is 62MM or less at its largest point."
Old Aug 18, 2008 | 03:21 PM
ZUL8R's Avatar
Default Re: H2 Racer needs help! (Austin)
uh oh... ive never read the rules to the fullest to be honest just going by what Karl and JOhn have told me, maybe i should take a look
Old Aug 18, 2008 | 03:22 PM
bosco500's Avatar
XBox 360 &gt; PS3
Old Aug 18, 2008 | 03:33 PM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">uh oh... ive never read the rules to the fullest to be honest just going by what Karl and JOhn have told me, maybe i should take a look
Here are the 2008 Honda Challenge rules, with the changes from 2007 highlighted:
http://www.nasaproracing.com/r...s.pdf
2/20/08 addendum - http://www.nasaforums.com/view...20579
7/3/08 addendum - http://www.nasaforums.com/view...22883
I keep a copy of the rules, as well as the addendums with my log book.
Old Aug 18, 2008 | 03:54 PM
ZUL8R's Avatar
great! I couldnt find a Type R throttle body,, or they just wanted WAY too much (shane clearing throat... Chaad)
Looks like i will be going back to stock if thats the case
Nothing ever goes my way
Old Aug 18, 2008 | 04:03 PM
bosco500's Avatar
I just ordered a Type R long block since I fried my new motor at Road Atlanta. PM me your address and I'll mail you the throttle body to use. I'll have it by next wed.
Old Aug 18, 2008 | 04:06 PM
ZUL8R's Avatar
Default Re: H2 Racer needs help! (bosco500)
my dyno tune is scheduled for thursday
Old Aug 18, 2008 | 04:19 PM
Lo-Buck EF's Avatar
wish i could help ya out, but i'm on a itty bitty tb but good luck at nat'ls.
Old Aug 18, 2008 | 04:23 PM
ZUL8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">wish i could help ya out, but good luck at nat'ls. </TD></TR></TABLE>
Thanks, at this rate im gonna need it
Old Aug 18, 2008 | 06:13 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">great! I couldnt find a Type R throttle body,, or they just wanted WAY too much (shane clearing throat... Chaad)
I can bring one to Nationals for you. $140.
2 issues with it-
1) BYO Sensors, TPS and MAP.
2) "Backup" spring under the TPS is missing. It broke into pieces and jammed the throttle open. After taking it off it works like a charm.. of course I already got a new ITR TB to replace it.
http://www.roadraceautox.com/b...art=1
It's actually a Euro R 62mm throttle body. Bolts up same as ITR though. I have an ITR TB on my Euro R IM at the moment. Lemme know if you want it.
-Chris
Old Aug 19, 2008 | 05:50 AM
Redcivic92's Avatar
HT White Ops
Shane, I have a TYPE-R throttle body but in order to use it you have to let me beat you at Nat's. PM me if you want to use it.
Fo-Do Fanatic
Feb 14, 2011 10:27 AM
Integacivic
Jul 31, 2004 01:59 PM
JdMcRxSi
Mar 11, 2003 03:16 PM
zilverz
Jun 23, 2002 12:58 PM
