For anyone struggling to remove crank pulley bolt come inside...cheap solution
And it is cheap too.
Went to local CHC home store and found this pipe fitting. It measures about 1 7/8" overall on the socket part. The opening on the crank pulley is about 1 15/16". This is a little sloppy but it worked. Fitting was like $2.90.
Put pipe wrench on the threaded part as seen in the pic. Wedged it between the lower control arm. Used my crapsman wrench with a 2 ft breaker bar on the end and got that sucker loose.
Hope this helps someone.
haha YES! my brother found a huge nut in the street at work one day and we used it the same way, that pulley is a s.o.b.!
Draggin99Si
59
Feb 20, 2005 11:59 AM
SuicideSlide
Oct 9, 2004 08:27 AM
