+0 offset on an ep3?
Old Aug 17, 2008 | 09:58 AM
02_Si_FTW's Avatar
Default +0 offset on an ep3?
Would a +0 offset look weird on an ep? Havent seen it. I currently have +20 i believe and it looks fine, but the fronts are still sunken in a little. Im new the the wheel stuff so dont quote me if I just said something stupid
Old Aug 17, 2008 | 10:05 AM
Todd00's Avatar
I said I don't want a title!
Default Re: +0 offset on an ep3? (02_Si_FTW)
I wouldn't recommend running a 0 offset, at all. Not only will you rub on bumps and be forced to roll your fenders, but offset that much is also much harder on hub/bearings.
Old Aug 17, 2008 | 10:09 AM
Ellerstein12's Avatar
Default Re: +0 offset on an ep3? (Todd00)
16x8 0+ offset Sportmax's
Old Aug 17, 2008 | 10:11 AM
02_Si_FTW's Avatar
Default Re: +0 offset on an ep3? (Ellerstein12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ellerstein12 &raquo;</TD></TR><TR><TD CLASS="quote">16x8 0+ offset Sportmax's
LULZ. These are the exact wheels i was planning on getting. Exept 15x8 0+. They look sick on that ep.. mine is a little more should I say... stock haha
Old Aug 17, 2008 | 10:15 AM
02_Si_FTW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't recommend running a 0 offset, at all. Not only will you rub on bumps and be forced to roll your fenders, but offset that much is also much harder on hub/bearings.
eeeek... I may have to listen to you now todd, cus the last time i didnt you turned out right! haha. I was just looking at cheap wheels and these are only like 280 bucks shipped . Getting my 15x7 42+ PIAA fr7's next week and would mind having a set of cheap rims
Old Aug 17, 2008 | 10:20 AM
i know the guy has 205/40/16 size tire which is a bit of a stretch for that size wheel but he doesnt rub
Old Aug 17, 2008 | 10:46 AM
02_Si_FTW's Avatar
If the great todd approves I may do it. I must admit though, they look sick. Just worried about the fender issue that may happen.
Modified by 02_Si_FTW at 8:25 PM 8/17/2008
Old Aug 17, 2008 | 02:11 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ellerstein12 &raquo;</TD></TR><TR><TD CLASS="quote">i know the guy has 205/40/16 size tire which is a bit of a stretch for that size wheel but he doesnt rub
How??? Especially in the front as the car doesn't gain camber when the suspension is compressed. That wheel sticks a good 2" outside of the fender.
It may be that he has that silly-small 205/40/16 on a 8" wide wheel (which is kinda dangerous on that heavy of a car FWIW). Or, he smacks the bumpstops first because there is no suspension travel. Either way, It's a bad setup.
Honestly, I would not run a +0, but that's me. Too many compromises and not enough benefits, unless you like rubbing and having that 'euro VW' look.
The proper way to run a 0 offset wheel is to cut your fenders and install fender flares. That way you canput a real tire on the car and keep suspension travel.
Old Aug 17, 2008 | 07:26 PM
02_Si_FTW's Avatar
I agree with todd. I googled sportmax 002 and what do you know... vw forums haha... WEAK
Old Aug 18, 2008 | 09:04 AM
JamesL's Avatar
Honestly, I would not run a +0, but that's me. Too many compromises and not enough benefits</TD></TR></TABLE>
Old Aug 18, 2008 | 02:13 PM
crazyflip's Avatar
I HAVE A 0 OFFSET. RIMS STICK OUT ON MY EP3. I'M ORDERING FLARE SOON. ONCE I SAVE UP.. AND HAVING THE FENDERS CUT. BUT DAMN HELLA MONEY THO.
Old Aug 19, 2008 | 06:09 AM
SkoundrelUSA's Avatar
cute little bastard
The proper way to run a 0 offset wheel is to cut your fenders and install fender flares. That way you canput a real tire on the car and keep suspension travel.</TD></TR></TABLE>
I'm not doubting your reasoning, but supreme/bimmerfrik (the white EP above) has ran that setup for a long time. I was really interested myself in doing that setup also. Tried talking to him and basically said he didn't run into any problems. It definitly sounded like too much work so I'm prob not gonna do it.
Other people have done it too and seemed to work out but yeah its work.
I've heard going with the Sportmax 501s instead (+15) is an easier setup to maintain. Usually just have to roll the rear fenders and run negative camber.
This guy is actually selling his wheel/tire setup on ephatch. Pretty sure he's had this setup for a while too.
Old Aug 19, 2008 | 06:13 AM
dschybrid's Avatar
Default Re: +0 offset on an ep3? (SkoundrelUSA)
15's on an EP3 = fail
And whether or not a 0 offset will fit, depends greatly on the width and size of the rim.
Old Aug 19, 2008 | 06:20 AM
02_Si_FTW's Avatar
Default Re: +0 offset on an ep3? (dschybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dschybrid &raquo;</TD></TR><TR><TD CLASS="quote">15's on an EP3 = fail
I disagree. 15's with a nice set of tires are way hot on an ep. But to each their own.
Old Aug 19, 2008 | 06:48 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
That's because he is running a 205/40/16 tire.
1) Tire is way too short for the car and speedo will be completely off.
OEM Diameter: 24.2"
205/40/16 Diameter: 22.5"
This also makes highway driving a high RPM affair.
2) Tire isn't meant to support a heavy car (there is a spec for this...did the dude actually check it out?)
3) The sidewall is stretched too much. Period. This will cause odd handling patterns and have the potential for dangerous handling and/or tire failure.
Old Aug 19, 2008 | 07:59 AM
crazyflip's Avatar
heres a 15"
Old Aug 19, 2008 | 09:03 AM
02_Si_FTW's Avatar
Default Re: (crazyflip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyflip &raquo;</TD></TR><TR><TD CLASS="quote">heres a 15"
Cant see it too well but from my pov they look nice.
Old Aug 19, 2008 | 09:28 AM
charleso's Avatar
what part of the bay are you from?
Old Aug 19, 2008 | 11:14 AM
crazyflip's Avatar
Default Re: (02_Si_FTW)
sorry my call phone cam sucks..i just lowered the front a little more yesterday. but i'll get some pictures ones i get my fender flares cuz back stick out.
Da La Soul
Jan 23, 2007 09:23 PM
A.S.I.M.O
Oct 4, 2006 02:52 PM
Black R
13
Mar 5, 2003 11:15 AM
